Question about Amana ABB1927DE Bottom Freezer Refrigerator
Not cold my freezer is working fine. The fridge is not staying cold. I have cleaned it underneath and the back. Please help
  • Anonymous Oct 01, 2008
    same problem. mine is AFD2535des
I just had the same problem with the same fridge, unfortunately it was not a piece of insulation for me. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Posted on Nov 18, 2008
A friend came to fix it there was a piece of insulation caught in the damper. Thanks anyway.
Posted on Aug 20, 2008
6ya staff
SOURCE:
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Fridge freezer freezer not staying frozen
Clean the unit, maybe is derty, I had the same problem and I cleaned and now is working fine. had lats of dust on it. I had to remove the back cover to do mine.
May 31, 2012 | Refrigerators
Can I lean my fridge back to clean coils underneath? I am experiencing fridge not getting cool air . The freezer is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2011 | Kenmore Side by Side Refrigerator
My maytag side by side is not cooling right.when the weather gets hot and humid the freezer won't freeze anything and the fridge isn't cold enough.when the weather is cooler everything works fine. it is an...
Clean the condenser coils underneath the fridge.
Check condenser fan at bottom of back of ref.
that its not slowed or stopped
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Aug 02, 2010 | Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
