Archos Internet Media Tablet MP3 Player Logo
Posted on Jun 13, 2011
I no have a idea how put new game in my archos tablet 5
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
3150
Points
25
It is the information it was useful to me. But here it is more clear. Press here
Peter Carscadden
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jun 13, 2011
Peter Carscadden
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
810
Points
22
It is an android tablet so all android info would relate to it.
you can download games from a couple sources, you could download the amazon app store, (google it from the tablet) there are also a number of other app stores (AppBrain is another).
If you want the official android app store youre going to have to work a little for it.
these are the step by step instructions of how to install it http://www.jkkmobile.com/2009/11/archos-5-it-now-with-android-market-and.html
another option is to look up any game (ex. angry birds) in google + .apk
"angry birds .apk" download one from the tablet and open it then hit install.
you could then google various other games that way.
1helpful
Hi, my Archos 80 g9 display screen is broken, can i buy new display from you?
the display screens can be purchased but good luck finding some one to install it just google it and buy 2 because often some of them dont work from the factory ooorrr you can have archos fix it wich may be cheaper and easyer about 25% of original cost and they will test it and make sure it works before sending it back or send you a new one the screen problem is not specific to archos its specific to that type of screen they have a half life of about 5 years but may die sooner under constant use or abuse and some die as soon as they are powered having archos replace it prevents you from having to buy multiple of them to find a good one samsung also uses the same type of screen but does not use the laminating or layering proces that archos uses to increase the durability and third party screens also dont have this eather so having archos do it will also ensure you get a laminated and layered set up that will last you a bit longer than one you might purchase after market and have some one put in for you
1helpful
Archos 5 internet tablet won't play youtube video from youtube them selves or via mobile youtube
Hello wilko1974, This has been an on going issue for Archos 5 users. The new youtube supports flash 10.1+ and the Archos 5 only supports 9. Unfortunately there does not seem to be a clear cut solution for this issue. Archos has not released a firmware update for this and with their new devices it there support for older devices has lowered. I have found that choosing the lower play button that appears over a video plays on Archos more often than the top button. I would recommend trying this and seeing if you get better results. Another possible solution is to open the video in a new window with the link on the top right of youtube video. This however is not on all youtube video pages and with the currently layout is on accessible when the video submitter enables it. It also help to have the latest firmware updates that can be done directly on your device. Hope this helps, Greg
3helpful
2answers
Broken screen
Here are a couple of links of were to get a replacement LCD Screen.
It should come apart fairly easy and the lcd ribbon should unplug so then you can place the new one in and plug it in.
I hope this helps to give you an idea of the cost.
http://shop.ebay.com/i.html?_nkw=Archos+5+lcd&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Archos+5+screen&_osacat=0&bkBtn=
http://shop.ebay.com/i.html?_nkw=Archos+5+screen&_sacat=0&_trksid=m270&_odkw=Archos+5+lcd&_osacat=0&bkBtn=
10helpful
3answers
Recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Archos 5 Media tablet
put the videos in the flash folder
3helpful
Itunes on Archos
You have to change your music from Itunes format to mp3 format and use windows media player to put you music on your archos. at this time apple does not allow any other media play besides the Ipod to use Itunes. sorry.
Hope this helps
please rate fair.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
?videos and movies to my archos5
without the video podcast plugin you can only use wmv and avi formats if you have the plugin then mp4 quicktime and ipod video should work.. Following lisks are for free Archos games and movies. Movies actualy for psp but as i said if you have plugin they shoul work or you can convert them to avi or wmv
link for archos games Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://brys-psp-help.webs.com/archosmoviesandgames.htm
link for archos movies Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://brys-psp-help.webs.com/pspgamemovies.htm
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
