Question about Teac A-H500 Amplifier
Loss of audio output right channel
As described above, I suspect the audio amp has blown. The output has not gone completely, but is greatly reduced. I will check the outputs/cablingat rear. Any other suggestions ?
  • Teac Master
  • 5,699 Answers
Take a look inside see if the amp uses transistors or an IC. If it uses transitors you can put a Ohm meter accross the leads (no power on) If it reads 0 (digital meter) or the pointer swings full over on the leads of any the transistors it's blown. If an IC then the thing might look damaged.
Posted on Jan 27, 2009
SOURCE:
No audio from main speakon outputs A and B
Hi, I think in most amps switching to bridge mode simply means the amp supplies its total power through the left channel only. It's the best way to use all of your amp's power but nothing comes out of the right channel. Having speakers connected to both channels would simply mean that only the Left channel works, it would not blow it. Some amps have the speakers wired to binding posts and this varies according to whether you want mono, stereo or bridged. I can't help with the power board sorry
Apr 07, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
What can I do about no output from right rear channel
Check to see if speaker is blown use another speaker. If it is not blown then your amp has a blown channel local audio shops may know of where to find repairs for your amp. hope this helps.
Jun 11, 2010 | Jl Audio 500/5 Car Audio Amplifier
Roland KC-500 has power but no sound.
You need to determine if the power is getting to the audio amp section. For instance with the volume full up is it humming etc?
As a 'rule' it's unlikely that both left and right channels will fail at the same time (unless you have done something silly with the amp) you are looking for something that is common to both channels. Which is why the power section is first suspect. The exception to the rule (above) is where amps use say an IC power amp for both channels. You will find this IC on the big heat sink. Check whatever is on that anyway for damage or burning.
The only other area could be the pre-amp part. Again this could be a single IC controling both channels, so it's failure could cause a loss of sound. By the way if you can hear music/sound coming through when you put it up to full volume the pre-amp will be generaly good.
Nov 23, 2009 | Roland MMP-2 2-Channel Amplifier
Hi i have an audio source 300 watt amp with a&b speaker outputs. the problem is that no sound comes from the left side outputs a or b. the right side works fine thank you mike
You have a blown channel. If you are experienced with electronics repair, use the right channel to assist in diagnosing the left. Both channels should be efectively identical. In most cases, the defective parts are the output transistors. You should be able to A/B the output amp sections.
Let me know if you need further assistance.
Dan
Jan 14, 2009 | Audio Players & Recorders
DENON PMA520 Amp. Suspect left channel not working as set bias to all left and get nothing out of left speaker. Right speaker working. Tried interchanging speaker connections and get same result from...
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Jul 27, 2008 | Denon Audio Players & Recorders
I think my amp is broken
Finals/outputs are toast. Get it serviced to get back to sweet music...accordianman
Feb 21, 2008 | Denon AVR-2807 Receiver
Reduced audio output from right channel
Try lightly tapping on chassis to see if you can get audio to cut on or off with vibration if you can most likely cause is bad solder connections. This unit is well known for poor solder connections especially around poweramp driver IC's IC701, IC501. Also Electrolytic Capacitors in unit have fluid in them and heat Evaporates the fluid causing them to not operate properly over time . Caps that usually go bad are around parts that run hot like Power amp drivers
Just a couple likely suspects.
Try unplugging overnight to give unit a Good Reset also double check all setup settings.
If you need service manual I may be able to get you one
[email protected]
Jan 19, 2008 | Sony STR-DE545 Receiver
Sound gone
disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
Dec 30, 2007 | Yamaha R-V1103 Receiver
No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Feb 16, 2007 | Bryston BP-25 Amplifier
Open Questions:
Teac A-H500 Amplifier Logo
344 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
