Philips TV model 20PS40S301,need to know how to clear Svhs blocking on this tv it has all channels blocked must enter a code number to get any programs when the tv is turned off, then back on. Thanks Chris
TVtechmaniac
  • 140 Answers
SOURCE: smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Posted on Oct 10, 2007
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code
for Philip sets is 0711, although it may say "Incorrect code" the first time
to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow"
key on the remote. Enter the override code, and enter it a second time if it
says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
DISABLE ON". The v-chip is now reset.
Posted on Apr 03, 2008
robotek
  • 1512 Answers
SOURCE: How do I unblock/block TV
Hi,are you wishing to set up the vlock for the set. Do you have the owners manual
Posted on Jul 06, 2008
SOURCE: Need manual for remote control
I need manual for cl015 also...
Posted on Oct 26, 2008
  • 179 Answers
SOURCE: i need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Posted on Dec 29, 2008
Anyone know what the code is to get my tv unlocked?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jul 05, 2012 | Philips Magnavox 27MS343S 27" TV
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
When Turned on the Screen says ''Locked''
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
Nov 25, 2008 | Philips Televison & Video
Smartlock code
Apr 03, 2008 | Televison & Video
GE: 13" Model13GP341 vchip parental control locked
magnavoxes and phillips tv's uses overide codes .those of you who have either of the two tv sets try this code 0711 hope it works.
Nov 05, 2007 | Philips Magnavox 27MS343S 27" TV
Smartlock code
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
277 people viewed this question
Top Televison & Video Experts
Electro Med Services...
