Loose power port
The power port is very loose and if I giggle it I can get power but its a pain and its started to make a bad sizzle sound, so is there any other way to power up my Averatec 6200 series (AV6210x61-01)? I like this laptop and I could have the port fixed but is it worth it cuz it kinda old? What does something like that cost, if you don't mind my asking????
Any help would great, as long as you don't suggest I take it apart myself. hahahaha Thanks PennySue
    Problem Solver:
  • 9 Answers
Change the cord first if this does not solve the problem remove connector and bypass with a power cord.
Posted on Dec 19, 2008
Avenger 2.5. Why won't it start?
first you have to tighten the loose wires at the starter to see what happens then go from there.
Aug 05, 2015 | Dodge Cars & Trucks
95 chevy lumina van some time the blower moter work, sometimes it dont. if you hit a bump it will shut off or start up as you are driving
This sounds like a bad motor or the mostlikely cause is a bad connection, check connection at the blower motor and look for a melted connector then you may want to take a look at the switch if there are no sign of loose or melted connector at the motor or the resisotr check the resistor after the motor then the switch, i would bet you will find a melted loose connector or motor is bad,good luck.
Jan 16, 2011 | 1995 Chevrolet Lumina
Its clicking
the clicking could be from thermal expansion or the thermostat turning off or on. Be sure it's a clicking sound and not a sizzling noise. Sizzling noises are caused by loose wires or burning contacts, this is dangerous.
Aug 21, 2010 | General Electric Water Heaters
Power cord port is loose and mchine gets no power
sounds like the power connector inside the computer finally gave out. Bad news is most likely it is built onto the motherboard which means it has to be replaced. If you are no longer under warranty this might be a little expensive to fix.
I would probably take it into a repair shop and get a quote for a new motherboard for it.
Mar 20, 2010 | Compaq Presario CQ60-220US PC Laptop
Dryer is squeking badly and drum seems to be loose. Dryer is about 9 old.
ther are rollers that hold the drum up and a big belt that wraps around the drum and the motor pully it sounds like one of the rollers has broken and has lessened the tension on the belt. pull the dryer out and take the back off. unplug first. giggle the drum and find what is loose the belt can be wareing out too. or a bracket may be broke that holds the pulley
Jun 25, 2009 | Dryers
Ptb2454grw - freezer appears to be fine if a bit frosty. The refrigerator isn't cold no matter what setting it's on. Any suggestions?
Frost on the interior back wall is a sign of defrost system failure. about a third of the way back on the fresh food control panel you will see a recessed knob (defrost timer). Use a flat blade screwdriver to rotate the knob clockwise. A click will be heard each time the knob advances. Continue until a more pronounced click is heard. You are now in the defrost cycle. Within five minutes, you should begin to hear sizzling sounds coming from just under the frost on the interior back wall. If you do hear the sizzling, replace the defrost timer. If not, the trouble will be a bad heater, defrost thermostat (located behind the interior rear cover) or loose connection. ****Before any screws are removed to make a repair.....DISCONNECT THE UNIT FROM POWER.
May 02, 2009 | Maytag PTB2454G Top Freezer Refrigerator
Microwave making noise, not heating
Was the noise something like someone growling into a coffee cup?
As odd as that sounds, that's a common sound for a bad magnetron to make, a hollow gurgling or sizzling.
It may be the magnetron, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Kenmore 62702 Microwave Oven
Computers & Internet Logo
David Payne
David Payne
