Question about Panasonic AG-DV1000 Mini DV VCR
AG-DV1000 Mini DV
Tape stuck in deck, will not eject. Code showing HO1.
Any suggestions? Who does repair on this unit?
Thanks for any help,
Sonny
  • 4,234 Answers
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
Posted on Aug 20, 2008
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Will not seat DV
most likely problem is a defective cassette housing.
Jan 11, 2009 | Panasonic AG-DV1000 Mini DV VCR
Unfortunately, all I know about Muncie is that I have relatives there. I'd go to the Panasonic website and use your zip code to locate a local authorized service center. Follow the link below and click on the "find a servicer" button in the upper right corner.
Dan
http://www.panasonic.com/support/?cm_re=1-_-Top%20Mast-_-Support
Aug 20, 2008 | Panasonic AG-DV1000 Mini DV VCR
AG-DV1000 Mini DV... ERROR F09
I believe that this error message indicates that the heads are not spinning. The tape should be ejected. This unit requires a servicer. There are a number of reasons for the heads not spinning. Finding out the cause in your specific unit will require testing and measurements with test gear. There are no user serviceable parts inside these units. Please see an authorized Panasonic service center.
Dan
Jun 02, 2008 | Panasonic AG-DV1000 Mini DV VCR
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Relace mainboard in mini dv tape deck
what symptom does it have? describe what it is/isn't doing; most of the problems I've seen with AG-DV2000s are related to either defective capacitors on the mechanism drive board or dried grease on the reel table positioning arms. I've never had to replace a main board in a 2000.
Jan 02, 2008 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV1000 ejecting tapes
This unit just needs the standard belt job. The rubber parts probably got old sitting around in the back romm of the university.
Could do it yourself if you are the like to take things apart type. Otherwise, a repair shop can do it very affordably.
Dec 16, 2007 | Panasonic AG-DV1000 Mini DV VCR
AG-DV1000P that powers off when tape is put in.
hi sir one of the reel or capstain motors should be not allowing to work something prevents it from rotating check with hands for fluidity of capstain or reel motor that power off is a conclusion of a short while motor tries to spin check for any thing broken in the guides or the path regards please don't forget to rate ,thx
Mar 30, 2007 | Panasonic AG-DV1000 Mini DV VCR
Panasonic AG-DV1000 Mini DV VCR Logo
308 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
