Question about GPS
Hi ! I have a HDS5 Nautica Insight I want to install on my 165 lowes boat. On the pwr side of wires I know the red wire is for pos. and the black wire is neg. but what is the yellow wire for and where does it connect too. Thanks for your help im sort of stuck. Tony
rizla
  • 1463 Answers
SOURCE: need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: missing fitting instructions
I just hardwired it into my vehicle, I use it for both road and water, I goggled garmin 276c wiring and I located the schematic. Unfortunately I cannot locate my printed hardcopy now. Give it a shot.
Posted on Aug 13, 2008
  • 4 Answers
SOURCE: Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Posted on Aug 28, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
Richie_asg1
  • 1036 Answers
SOURCE: c.b.radio-power won't come on.(red & black wire show short!)
The fault is probably at either end. Yes, it could have been reversed, but most radios are easily protected against this.
If you are getting no lights or anything when keying mic, then there may be an inline fuse along the cable. As you are getting continuity, open the case up, and look for any evidence of heat at the components nearest the power supply - particularly the protection diodes - Black cylinrical components with a silver band.
You really need a meter or scope to go in much further, and check supply voltages between components and -ve, and downloading a copy of the circuit diagram will help this.
The other main fault is usually the output power transistor - which needs a sink for all the power getting thrown at it. If you remove the antenna, it can quickly overheat and fail.
Both components can be checked in-situ for voltage (or not) but the output can only be tested with a scope.
Of course - the "on" light could have blown, so may be functioning without indications, - but I doubt it.
Also check Mic outputs on the plug to make sure that is working. Some units won't function if this is disconnected.
Posted on Jan 08, 2009
Lawrance hds5 gen 2 burnt out due to water leaking
depends on how old the unit is most the time they tell you oh well !!
Aug 06, 2013 | Lowrance HDS5 GEN2 83/200KHZ Lake Insight
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
I am installing a stereo in my car and the previous owner cut the wires and the labels are gone. The stereo I am installing has 4 wires other than the speaker wires. They are: +Battery(Yellow), ACC (Red),...
Here you go.
Radio Side -- Car side
12v (Yellow) -- Orange/Black
ACC (Red) -- White/Black
Ground (Black) -- Black or chassis ground(bare Metal)
Pwr Ant (Blue/white) -- Pink
If your not adding and amplifier than your system remote should be used for power antenna which is the pink.
Hopefully this helps
Please Vote & Rate thx
Mar 08, 2010 | Pioneer 50W x 4 MOSFET Apple iPod...
Trying to figure where all the wires connect on a/c contacter?
The two wires coming from your inside unit. They are the low voltage wires go on either side of the contactor coil. You should not have two blues on one side. see if the black wire comes from inside unit. Rus
Jun 25, 2009 | Coleman Heating & Cooling
I have a kenwood krc-557l and dont know what wires are what...
Red is "Key on Pwr"
Yellow is "Constant Hot" always powered
Black is "Ground"
Blue is "Pwr antenna or amplifier remote turn on"
This is tapping my memory a little, however, I believe stripe is positive on Kenwood and solid is negative. The easiest way to test spkr wiring is to connect your pwr,gnd,etc. then make sure all other wires are individually taped barring one. Use any speaker, turn on the radio, connect one wire to pos & one to neg on spkr, look at the cone of the speaker, if it pops out, you have the correct wiring "in phase" if it's incorrect, the spkr will appear to pop "in". That's "out of phase" reverse your wiring.
Hope that helps
May 17, 2009 | Car Audio & Video
Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Mar 15, 2009 | Electrical Supplies
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Help with install on clarion vrx935vd
I love Clarion
1st RED is + direct to battery
Yellow is + pwr to ignition so when you turn the car off the radio can still say on if you choose
black is - and ground
these are importantant first. once you have pwr you can easily work out which of the 8 other wires are pairs 2 frnt spkrs and 2 back speakers if theres 2 extra plugs for the amp or woofer(if screws run a nice thick speaker wire. But with Clarion I dont beleive you need an amp or woofer thats how good they are just have kickass speakers frnt an back
you should be able 2 find the pwr cables from the existin radio if not the yellow wire leads to the igniton and you can run a red wire staight to the battery and screw the black wire to the metal chasis(oh the blue wire is for a pwr antenna or aux and is not needed unless youve got a pwr antenna.
your speaker color code will be like eg.grey and grey with white stripe,will be one pair green another pair ,but the 4 spker pairs are skinner than th pwr cables
Spkrs have a + and - too the difference is you cant blow the spkr by trial and error its just if its wrong it will sound muffled so try both ways then youll know whats best. pwr must be correct make sure red on red and blacks on black then press on then play with your speakers then find the yellow cable that runs to the ignition then to the radio so when you turn the ign the radio comes on and when you turn the motor off you can turn the radio on cos youve also got a direct to battery connection.
Man you are gonna love your sound system
Im happy for you
Clapster
Feb 24, 2008 | Clarion VRX935VD Car DVD Player
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
