Question about Samsung HLP4663W 46" Rear Projection HDTV
HLP4663W 46" DLP TV noise (fan?)
This morning, while the TV was on, a noise started coming from the back of it. It sounded like the fan, so I popped the back panel off the TV and located it. With this panel off, I can see the fan, and the lamp, so I disconnected the power to the fan and started the TV back up to see if the fan was the problem. The noise continued, so I'm wondering if there are two fans, or if something else could be causing the noise.
Any ideas?
thanks
  • 2 more comments
  • jaldrova Sep 25, 2008
    So after a month on back order, my new color wheel finally arrived. I put it in, put everything back together, and now when I turn it on the lamp light blinks on the front :( I had everything apart and set safely in another room so I don't think I damaged the lamp. I've rechecked all the connections and everything seems to be in order but the lamp light still blinks. The small fan starts up, but the larger fan by the color wheel doesn't, but I think that's because the lamp doesn't come on. Any ideas?
  • jaldrova Sep 26, 2008
    Well I fixed the lamp problem. I was digging around on this site and found a comment about that copper ribbon cable that comes off the color wheel. It turns out I had it backwards, and flipping it around has fixed the problem.
  • jaldrova Sep 27, 2008
    New problem - The color wheel is replaced, the ribbon cable is inserted properly, and the TV now turns on. The problem now is the entire image is about 1" too low. There is a black space at the top of the screen and the cable information that displays at the bottom is chopped off. It looks like I just need to shift the entire image up an inch, any information on how to do this?
  • naharlem Sep 28, 2008
    There is a noise coming from the back of the TV. It sounds like the fan
    is making a very loud noise when it comes on and goes off. It won't
    even stop when we turn the TV off. Any idea how serious a problem this
    is?
    Scholar:
  • 65 Answers
It's probably the color wheel.
Here's a good article about it.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Posted on Sep 04, 2008
  • Joshua Blaine
    Joshua Blaine Sep 26, 2008
    Good job on solving the problem whenever you put something in check and recheck the connections are right if something else stops working doesn't work.
There is a noise coming from the back of the TV. It sounds like the fan is making a very loud noise when it comes on and goes off. It won't even stop when we turn the TV off. Any idea how serious a problem this is?
Posted on Sep 28, 2008
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Recently and occasioally the set makes a sound like a fan hitting something
If its a constant grinding noise it may be a bad lamp fan or a color wheel. But only if your TV is a DLP...
Aug 25, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
TV made humming noise for past few months and after it warmed up the humming would go away. It that same thing today and a pop noise came and the screen will not come on, and the tv shuts off and then...
i took off the back and pulled out the the fan. Then put in a fat screw between a slight gap whick kept the fan from hitting what ever is causing the noise. probably not safe but nothing bad happened yet.
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP
it sounds more like the power supply gone bad
Oct 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
DLP TV Samsung HLP4663W
Your problem could be your lamp is not seeted all the way in. Take you lamp out and put it back in. Or it could be you ballast that lights you lamp is bad. You may need a new ballast.
Mar 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
992 people viewed this question
Henry  Thomas
Henry Thomas
