Question about Kenwood Excelon DDX-7015 Double Din Car Audio Stereo DVD CD MP3 Player 6.5" touch-screen Car Video Player
DDX512 Video Playback Bypass
I have a DDX512- id like to bypass the parking break- do I just ground that wire to same place I ground the stereo?
Yeah jus ground the wire, thats what i did
Posted on Mar 31, 2009
  • 1,586 Answers
I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
Posted on Aug 20, 2008
Parking break bypass axxera axv820
You can try attaching the parking brake directly to ground to bypass the issue. However, some systems require a change in voltage each time system is powered down. If this is the case, you can place a toggle switch inline with the parking brake wire, attaching one side to the wire and the other side to ground, allowing you to apply the ground and remove it when necessary.
Feb 11, 2013 | Dual Car Audio & Video
How do i view video without hooking to brake cable?
If you choose to bypass the parking wire without using a module manufatured for that purpose; try connecting the parking brake to ground and test. If this doesn't work, you make have to use a two wire toggle switch. Connect one side of the toggle switch to ground and the other side to the stereo's parking brake wire. Switching it back and forth will supply the necessary ground for the stereo.
Mar 09, 2011 | Clarion Electronic Automatic Video Lockout...
I am about to install my boss bv8962 unit into my vehicle but I want the parking break safety feature bypassed. What do I do differently during installation so that my passengers will be able to watch tv...
Yes, you can bypass parking break feature by connecting the corresponding wire of BV8962 to ground, also you could add a 3 pin toggle switch to get a normal and bypass mode switch, this can be wired of this way, the common pin of toggle switch to your video unit, at the other pin, it could be connected the parking break wire (normal mode) and the remaining one to ground (bypass mode).
Feb 26, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Bypass didnt work
Connect the parking break wire to the chasis ground. This is a safety feature that is used so the driver will not view the movie. I have these units installed on our boats and just simply hook to ground.
I hope this helps!
T-Mo
Feb 09, 2008 | Car Audio & Video
Car Audio & Video Logo
397 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
