I was playing guitar through my fender 85 amp and the volume suddenly cut out to almost nothing and I couldn't make it loud again?
  • 3 Answers
The speaker could be blown. Try touching a 9volt battery to the terminals on the speaker. If the speaker makes a popping sound its not blown. The other culprit could be the input jack of the amp. If its soldered directly to the board. The retaining nut may have come loose and the jack wiggle around with the cord tension. resulting in a solder connection breaking at the board. But that usualy will give a ground hum or no sound at all. So im leaning towards a blown speaker. (providing its a solid state amp) If it's a tube amp. it could be that one or more of the power tubes are bad or have a vacuum leak and may need to be replaced. ( you have to replace all the power tubes at the same time and have the amp biased.
Posted on Aug 21, 2008
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Fender hot rod deville 212 111. On the 2nd and 3rd distortion chanels the noise coming out of the speaker is very loud. Is this normal? Hard to play through the noise.
Hi. If the volume and drive levels are considerably low but you still hear a noise, you may want to consider trying a different guitar cable. The noise may be coming from a ground loop which is being amplified and overdriven by the amp itseld. I hope this helps. :-)
May 29, 2011 | Fender Musical Instruments Corporation...
My Fender 212R 100W 2x12 Guitar Combo Amplifier keeps on cutting out. The guy I took it to says there is something wrong with the cylinders? I also could have heard that wrong. I honestly don't know much...
You had best get a second opinion! When somebody says "there is something wrong" means they don't really know the details enough to give you an estimate even. If the amp cuts out sharply I would suspect that: 1. Bad volume control 2. Cracked circuit board 3. Bad solder joint on circuit board 4. Bad jack. These are in order from least to most likely.
Jan 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have Fender Hot Rod Deluxe and Blues Deluxe amps.After the amps are in use for 20-30 minutes, volume just flat out fades to almost nothing. I have had it checked out and technician could not reproduce...
I want you to do a test. while using the amp plug a pair of headphones into the preamp out... note you will only hear stuff on one side if they are stereo phones and the sound may be fairly weak... while the unit is operating correctely then unplug phones and use it. When it fades out plug in phones compare the level when it was OK... If the preamp output fades lower as well, then we know problem is in the preamp section...
We can do a lot of troubleshooting without opening the amp.
I see nothing in the scheamtics that should be an issue causing this...
Since it didn't fail for the tech, think "what was different?". Are you connecting something else? Foot pedal? Temperature? :Loudness of playing?
Now what else is in common to these two units... AHA! The guitar...
If your guitar has a battery in it, the 20 to 30 minutes fading would correspond to a battery failing and then recovering after you unplug the guitar for a while.
Apr 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
On top volume & top drive with nothing plugged in it feedback
You should check if the thing does it with a guitar plugged in.
The shorting switch for input connectors that keeps the input grounded are prone to failure.
Mar 06, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Loud buzzing noise when I turn amp on -won't go away
change the plugs on the chords.or both.they loose their resistance.good luck.
Feb 28, 2010 | Fender Audio Players & Recorders
When i turn on my amp it makes a loud beeeeeeeeeeeeeeeep.
Turn the volume down.
Check your gain.
That should solve it.
Feb 05, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
 Grubhead
Grubhead
