Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Drum bearings hello,thanks for reply to my problem!. Would i need any special tools to replace bearings. thank you
  • 1,543 Answers
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
Posted on Sep 02, 2008
Where do you get the tool to compress the spring when replacing Maytag top load thrust bearing? Even with the .032 washer, I can't get it on.
Hello, Thank You for using FixYa. I will be helping you today.You dont use the spring tool when replacing the thrust bearing. Only when removing the brake.It can be hard to get on but no special tool needed.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag PAV2300 Top Load Washer
Repair front wheel bearing assembly
no special tools in particular just the usual or necessary tools required.. 1stly u remove the Tyre and the caliper then u'll see something like a long rod dats the bearing
Aug 02, 2010 | 2004 Mercury Mountaineer
How to replace bearings in hotpoint washing machine. Has anuone got a plan view of what I need to do.
Hello,It's fairly straight forward,not easy though.The facial comes off(take the dispenser out and remove the four screws), front of the machine comes off (3 screws at the bottom and 3 behind the facial,the outer tub front comes off.)The pulley on the rear comes off,the inner drum can be knocked through.This gives you access to the bearings and bearing seal,not the easiest to get out.A lot of the time the outer race is left behind from the front bearing and it's a nightmare to get out.Hotpoint use a special bearing tool,get yourself a spider and bearing kit as well as a new tub seal.
Thanks
May 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drum bearing
look to see if there are any tamper proof fasteners on the machine, if not then as long as you have torx head and allen wenchs with the other basic tools you should be good to go
Jan 31, 2010 | Indesit WA 125 Front Load Washer
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Drum bearings
hammer and cold chisel but try to hit the outside of the bearing not the middle otherwise it may disintegrate. you really need a simple bearing press to put new bearings in
May 07, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Bearings-maytag washer
And you probably need special pullers/press tools too. Look up a web site see in there is a manual on offer
May 08, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
