Question about Compaq Presario R3000 Notebook
All kinds My presario R3000 r3275Us power cord does not maintain contact, or recoginized contact with the pin, also the blue tooth button quit functioning as well as the power on switch.. is it the mother board
  • bwmoser Aug 19, 2008
    so you think the power switch and blue tooth switch are diretly related??
  • 72 Answers
It's the power connector on the motherboard, and the more you wiggle the connector on the cord to make contact, the more you damage the motherboard (from the sparks and heat).
There are a number of sites on the web that offer to fix that problem (it's probably the worst part of the design of any laptop) for prices ranging from around $75 to $200 - try this search to find someone you feel is competent:
http://www.google.com/search?q=notebook+power+connector+repair&ie=utf-8&oe=utf-8&aq=t
Posted on Aug 19, 2008
  • Al Klein
    Al Klein Aug 20, 2008
    If there's no power getting from the power jack to the motherboard, nothing will work. But if there's power and the bluetooth doesn't come on, you have two problems. (An external bluetooth dongle is about $10, and fixing the switch woiuld probably cost a few times that, so it wouldn't pay to fix it.)
Find blue tooth board
Try www.ebay.com Type make and model of laptop and scroll through the list.
May 27, 2012 | Compaq Presario R3000 Notebook
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
How do you reset the device?
first you must put the blue tooth device in pairing mode,most blue tooth device manufactures use the power button for this ,by holding the power button down for 6 to 10 seconds when turning the device on it usually puts it into discovery mode,a solid light might stay on ,then you have to enter a pairing or pin code.Now most manufactures of blue tooth devices use a 4 digit factory pin pairing code they are asw follows 0000,.1234,9999,or 1111 i hope this helps
Feb 26, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
My compaq presario r3000 wont charge. its plugged in but when i unplug it it immediatly turns off. the battery life constantly says 0%. it wont drop from that or get any higher. in the bottom right hand...
Sounds like the battery, had similar problems.. if you purchase a new battery make sure you get the right kind there are two types, an 8 cell or 12 cell..
The fix for my pressario involved completely stripping it and soldering 3 pins on the power connector on the mainboard.. not difficult but no mean feat.. now works perfectly (with the inclusion of a 12cell battery)
Dec 28, 2010 | Compaq Presario R3000 Notebook
Where is my wireless switch on my Compaq Presario R3000
Right side in the front at the corner ,,little round button ,,it will glow blue when on,,
Dec 13, 2009 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Presario R3000 quit recognizing the DVD/Writer
I removed the drive and reinstalled it and solved the problem. Thank you for your fast response. Obviously HP doesn't out us little people.
Mar 07, 2008 | Compaq Presario R3000 Notebook
HP pavilion will not shut down
pull the power cord out and the battery (or just let it run out). Then, try turning it back on again. If it does the same thing again then yes it may be old blue death and your harddrive may be worse than dead. I don't believe that the power button doesn't work. Hold it in for 10-15 seconds or so, any computer is DOS programmed to respond to the power commands above all, even above the dreaded blue screens. Let me know if I'm an ******* and I don't know what I'm talking about or if you need more help.
Mar 07, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Compaq Presario R3000 Notebook Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
