Question about Sub-Zero 632 / S
Sub-zero model 532, not making ice
Stoped making ice one day , I was told it could be that the ice is frozen in the fill tube and to use a blow dryer to heat to melt ice, tube is clear of ice. Still no ice. Any ideas?
Thank You, Lanny
  • 1 more comment
  • rsbke Aug 28, 2008
    Ice Maker just stopped making ice.
    No error codes - just "ICE 01"
  • hpilikian01 Dec 01, 2008
    I did yous blower 2 times and it worked.but this time it did not help.
  • Anonymous Jan 18, 2009
    i have the same issues with my sub zero 632
  • 90 Answers
SOURCE: How to fix iced up and jammed ice maker for Sub Zero 532
There should be a screw or two that if removed will allow the unit to pull free. The rest you have seen...Take it out and let it thaw then replace it and see if it works if not then get a new one....
Posted on Feb 15, 2008
SOURCE: sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Posted on Apr 15, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 409 Answers
SOURCE: Refrigerator drain tube clogged, I cleared it, it keeps clogging-SZ 550 14 yr old
hi there,
the tube that you are talking about is the water line and it runs all the way to the icemaker. not sure about the copper line and it's also not a good idea, as cooper conducts electricity and you may damage your heat exchanger or even worse your compressor. i would have a technician come and take a look at this one. the mfg. should have a water line freeze kit available to remedy this problem.
Posted on Oct 03, 2008
Freezer fan not working - Sub zero 532 -
usually this is because the fan is clogged with ice and has frozen ice stopping it from spinning otherwise if you see no ice blocking the fan from spinning see the link below and purchase new fan and replace it.
Sub zero 532 fan Google Search
Feb 16, 2018 | Refrigerators
Where is the 690s ice maker fill tube? I am not getting ice and think the tube may be clogged with ice and needs thawing with hair dryer. Former owner says one day it just stopped making ice.
You can do that, but if it does it again you will need to order a new inlet valve. This where your water line is connected in the back. Rate me if I helped.
Aug 27, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
My 550 ices up behind crisper draws causing condensate tube to freeze solid
suonds like the tube is stoped up try to un stop it by small thin flexable wire or blow it out with air.hope that helps
Feb 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
632 sub 0 and not making ice
The only way is to take a hair dryer and try and defrost it. Sometimes that works and sometimes it doesn't depending on how frozen it is. Just be careful not to melt the line.
Jul 27, 2009 | Sub-Zero 632 / S
Sub Zero not making ice
if this happened when you shut down the purifier system and that feeds the fridge then yes most likely the problem or when it was shut down and then turned on again sediment could have been pushed into valve on fridge,find the shut off either under the sink or in basement,loosen the nut on water line just enough to see if any water leaks out,if not no water going to fridge,if there's water there you either have a bad water valve or a bad ice maker,if that's an older subby you can use a whirlpool ice maker instead of sub zero ice maker,i think they want like 400 bucks for a sub zero ice maker,also if you had to get in there with a hair dryer before most likely the fill tube was frozen and this usually happens from a bad water valve,water leaks through the valve slowly when it's off and it will freeze in the tube,if that ice maker is over 7 years you might want to change out the valve and ice maker because the mold rots out,you can look at it,if you see any peeling inside the mold change it out,also if that has a whirlpool ice maker in it pop off the white cover,get a jumper wire and stick it in the V and L that will send power to the water valve and the ice maker should fill,if not the valve is bad,if no water is going to it the valve will buzz,if water fills stick the jumper into the T and H this will cycle the ice maker but you have to hold the switches in in the back left side if this is a bottom mount freezer or like i said before just replace the ice maker and the valve,you can google clarke and get the phone number,call them and give them the model and serial numbers and they'll send the parts to you,if that's an older bottom mount you can use the whirlpool ice maker,go here and you can see it part wpw10190965
https://www.repairclinic.com/PartDetail/Ice-Maker-Assembly/WPW10190965/1471727
you'll find the model and serial numbers on the top hinge on the fridge door if it's a bottom mount,if it's a side by side open the freezer door and look at top hinge and numbers will be there.hope this helps and good luck.
Dec 05, 2017 | Refrigerators
No water for my sub zero ice maker system 532
Check in two places either behind the fridge or under the cabnit where the water supply is. If not there then check up underneath th back of the fridge
Feb 14, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Jul 30, 2008 | Sub-Zero 632 / S
Nov 21, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
568 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
