Question about Video Game Consoles & Games
I was switching my PS3 from using the hdmi cord to using the regular cord so i could use it on another tv. when i switched the cord settings it had to switch the tv settings on the PS3 from 1080p to like 480i, i guess i chose the wrong one and now the settings are still on hdmi and i can hear the sound but i cant see the picture no matter what resolution the tv is.So i cant see the settings menu to fix the problem i just get a blank screen and sound
  • 50 Answers
So u must go n plug the hdmi cable in a tv dat support an hdmi feature so u can be able to fix the problem from the menu.....if it's not lkike that i think u can use the AV cable on a normal TV ....so u can fix it as well
Posted on Aug 19, 2008
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
Yesterday, i played my PS3 on a hd tv using the hdmi cord for the first time, then when switching back to a regular tv and using the red, white , and yellow rca cord, the ps menu didn't show?
There are a few ways to remedy this situation.
1) If you have access to that HDMI port on the TV, plug it back in and switch the settings back to composite. Your screen will go black which means you did it right.
2) I've only done this once and it was a trial-by-error step. Plug it into the tv, turn it on, hold your finger over the power button to turn it off. Hold your finger over the power button when turning it on. After a few cycles it worked for me. Key thing is to keep reseting it.
The safest thing to do is get the HDMI tv to switch your settings back
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
78 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
