Question about InFocus ScreenPlay 4805 Multimedia Projector
Need to invert the picture--ceiling mounted
It is mounted on the ceiling and the picture displayed is upside down--how do I change it?
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Posted on Sep 28, 2008
Go into the menu and select ceiling mount
Posted on Sep 07, 2008
SOURCE:
Ceiling mounted this projector,now the picture is upside down.how do i get it the right way up?
In the setup menu there is a choice to invert the picture. Look for that and choose inverted.
Jan 01, 2016 | Office Equipment & Supplies
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
The screen switched upside down while i was trying to adjust setting - how do i get it back right side up?
Go into the setup menu. Go to Display and there should be a setting to invert the signal. You have inadvertently toggled that setting. There are settings for rear projection called image reverse (don't change that one and also for inverted which could be called ceiling mount.
Jan 30, 2011 | Mitsubishi HC6800 1500 ANSI Lumens 3LCD...
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Aug 25, 2010 | NEC MultiSync LT280 LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Upside down picture
YOU most likely have the thing mounted upside down that all
just flip and check the instructions
>if it is hooked up through a pc you will have to change the settings in on the pc( graphfic/diplay) ROTATE 90degress
PLEASE be kind if i helped and post more if you need help RATE this userKindofcheap
Aug 31, 2008 | NEC VT465 Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Polaroid PDM-0725
To change the screen upside right again just hold down the mode button until the screen changes upside right again , pressing the mode button changes the aspect ratio of the screen.
Oct 09, 2006 | Polaroid PDM-0725 Portable DVD Player
InFocus ScreenPlay 4805 Multimedia Projector Logo
690 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
