Question about Audiovox AVT1498 TV
This set is mounted in an 2006 model RV. We don't know if it is Digital ready for the 2009 date
Is this TV HD ready?
  • 2 more comments
  • dudcitypop2 Aug 19, 2008
    Neither the set nor the book tell us that the set is digital ready for the 2009 date
    Thanks Dan, we know that much, but don't know if this set is Digital compatable with the roof antenna.
  • dudcitypop2 Aug 20, 2008
    Thanks again Dan, that was the answer we were looking for. We have the coupon for the box. So now we know to go ahead and buy it. That was a big help!!!!!!!!!!!!!!!!
  • Anonymous Mar 22, 2014
    stuck on stand by
  • 4,234 Answers
Unless you are using an external antenna, it makes no difference. If you have cable, satellite service or FIOS, you are not efected. Only sets that depend on the over-air transmissions will be effected.
Dan
Posted on Aug 19, 2008
  • ABRsvcs Aug 20, 2008
    I was able to locate further info on the set and it is NOT digital ready. A converter box will be required.
    Dan
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
Does a hitachi 42 inch need a converter box to be able to watch regular tv
Which model do you have? The ATSC tuners were required in 42" TVs starting in the middle of 2005. Some Hitachi 42" TVs built before that date have an ATSC tuner but other models do not. The ones that didn't were usually called HD-ready TVs. For those models, you need a set-top box to receive OTA signals (except for some low power stations that continue to broadcast an analog signal).
If you provide your model number, I'll try to confirm the tuner information. If you look at the model information plaque on the back of the TV, you will see some information about when the unit was manufactured. If it was built in 2006 or later, you can be sure that the unit has a digital tuner.
I hope this helps.
Nov 23, 2014 | Televison & Video
I would like to know if this TV model is digital raedy.It has a MFG. date as 2000 I want to take it on a trip if it is digital ready. Thank you Thom
If the tv it is flat and tv LCD screen design than it is digital ready.It well be able to pickup free DTV air broadcasting from tv channels stations.If tv it have a big back and bulky design like it have CRT-tv tube.It well not pickup tv broadcasting in tv digital channels,all tv channels went digital on 2006.
Jun 30, 2011 | Televison & Video
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
LCD TV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
IS MY TV DIGITAL READY
Its tuner is NTSC, which will not tune in digital stations. I didn't see a DTV tuner mentioned anywhere on the specs, so don't think it will work. I myself have one and will soon purchase a converter box with the $40 rebate from the government.
Jun 10, 2008 | Sanyo DS24425 24" TV
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Digital Conversion 2/2009
No it is not HD ready, your set has a NTSC tuner the new digital sets have an ATSC tuner, BMW Rider
Jan 02, 2008 | Hitachi 50UX57B 50" Rear Projection...
Audiovox AVT1498 TV Logo
89 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
