Kenmore washing machine
Will not agitate and makes an awful sound
  • 5,911 Answers
Does the washer drain? If so, you may have a broken motor coupling. This may be the noise you're hearing. This is a common problem and is inexpensive to repair. The following link explains how:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If you do an inspection of the washer and find that it is not the coupler, you may have a more serious issue of a gearcase (transmission) or clutch failure. Both of these repairs can be performed without the aid of a repairman as well.
Please doublecheck your symptoms, and get back to me. Your intial description, however, sounds like a simple motor coupling problem.
NOTES:
A bad Motor Coupling will allow the washer to fill normally, but when it gets ready to agitate, a loud rattling sound can be heard. The washer will drain, however. There's usually the presence of black filings under your washer.
A bad Gearcase may will have similar symptoms, but there may be the presence of a honey colored oil under the washer and very loud grinding noise.
A bad Clutch will also exhibit similar symptoms. This is usually a little harder to diagnose without operating the washer without the outside case on. The clutch is located on top of the gearcase directly under the wash tub. If the clutch fails, the drive motor will turn the gearcase, but the clutch will usually slip and not engage the basket drive.
Let me know if any of my explanations sound correct. If not, post back with your complete model number and update me on what your washer is doing, so I can assist you further. I hope this helps you.
Posted on Aug 21, 2008
My Roper washing machine model RAL 5144 AW makes noise when it agitates - like something is loose.
Sounds like your agitator needs to have the agitator dogs replaced.If you take off the top of your agitator you can look down inside and see what's happening. Hope you find this helpful.
Jun 23, 2011 | Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
GE Top Load Washer
There is a plastic coupler piece that goes bad under the agitator. The agitator pulls straight off with a little oooompf. The coupler is bolted to transmission shaft sometimes i have to use a puller to remove coupler as its seized to trans shaft PLEASE rate my help as solved as it darn good
Oct 02, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
