Question about Innovage Touch-panel Phone 1502084
Phone won't install
Have panasonic 3 station cordless, trying to install Innovage corded on same line. Problem doing so. Can you help?
  • 4 Answers
I have the same phone. connect the Innovage to the line and connect your other phone into the data jack. if your Innovage phone is in use, your other phone may not work. i did this with my att cordless phone and it works great.
Posted on Oct 14, 2008
Need manuel
Posted on Aug 23, 2008
I'm so embarrassed...my cordless phone died and a friend loaned me an old corded one but I can't figure out how to get power to it. It's a Panasonic corded phone, Model No. KX-77020 whichi is...
Give it back to your friend. It won't work without a Key Service Unit.
Take yourself to any box store like Target with a $20 bill and get a Uniden basic cordless phone, or any drug store and buy a $10 corded phone.
Carl
Sep 20, 2011 | Panasonic KX-T7730 Corded Phone
I have a Panasonic kx-ta824 system that has been up and running for 3 years,flawless the cordless phones are dropping calls so I replaced them with 2 new ones, they are doing the same thing. The corded...
The problem sounds like it is the main base, the only advice I can give is change the phone cord between the base and the wall to see if that will help, the only other option is check the base for connection issues "inside the unit" and finally check your phone company and ask for a technician to find out if there is issues with the phone lines. If you still have problems, try a replacement base.
Jan 13, 2011 | Panasonic KX-TD7896 Cordless Phone
I have the panasonic handset phone. I have three lines. When I pick up the phone it goes automatically to line 3. If I have a call holding on line 1 from the desk phone how do I get to line 1 on the...
A lot depends on what sytsem the 7896 is plugged into. If it happens to be a TA series, you'll go into station programming mode (menu 99) and dial 11. The change this makes is that you will have to dial "9" to get an outside line, or 53x to pick up lines 1,2,3 etc. To get back to idle line preference, dial 12, but a cordless phone should never be set to ILP because you can't call internally or page.
Carl
Sep 21, 2010 | Panasonic KX-TD7896 Cordless Phone
Cord less phone
110,kamdhenu shopping centre,lokhandwala complex, building-3, andheri west, mumbai-400053
landmark---in kamadhenu shoppin center
Apr 05, 2010 | Panasonic KX-TG5632 Phone
I just want to make sure that I am shopping for the right product. We have a dental office with 1 phone#, but we have a rollover line. Our fax has it's own# which "was" what we called line 3 but as of...
Yes, you can use a regular 2 line cordless phone with your 4 line corded systems. The only concern is when you put someone on hold. The on hold function may not release if you have different makes of phone. If you already have Panasonic get a Panasonic 2 line cordless phone with the on hold feature.
Yes, you can just take line 3 and plug it into your new fax. I might suggest looking into a fax to email service instead of buying a new fax. If you receive more than send it's a great way to save on the phone line and paper.
Digital phones are pretty secure, no one will accidentally hear your conversations. It is not encrypted but I think it would be perfectly fine in your office.
Greg
Feb 18, 2010 | RCA 25205RE1 Phone
"no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
May 01, 2009 | Lands Phones
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
INNOVAGE 1604007
See #11 in the manual...try turning the spy prevention off.
Oct 23, 2008 | Innovage 1604007 Corded Phone
Innovage Corder Phone
My phone model number 18924 gives me a four beats of sound when I use my cordless phone connected to the same telephone line. When using the innovage phone, the sound is not there. Is this because I may have the wrong settings? If so, what is the correct setting? If not, please suggest what to do.
Aug 15, 2007 | Innovage 1604007 Corded Phone
Innovage Touch-panel Phone 1502084 Logo
74 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
