I just bought a laptop and we recently got a DSL connection, I'm not sure how to connect my laptop wirelessly ( Do I need anything else?).
  • 928 Answers
If you would like to connect wirelessly to your DSL connection you will need a wireless router if your modem is not a combination modem/wireless router (You can ask your ISP regarding this). You may go to
www.linksys.com and www.netgear.com so that you may look at routers that will suit your needs.
Posted on Aug 19, 2008
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
My acer 5315-2153 keeps asking for an isp
it shouldn't be asking for an ISP as most dsl modems even though they are PPPOE by nature, DSL providers have removed the necessity to add all the information to the configuration. I recommend removing all connections already present in the machine, not the adapters or anything physical just remove all known connections. don't run any kind of internet set up wizard because you don't need it. just connect the device to the router/modem. if you connect directly to the modem you'll need to reset it after connecting the new machine. If internet explorer/firefox/chrome are being used make sure you double check proxy settings and turn them off. this is listed under tools in the browsers. I would also make sure both the wireless and wired connections have been set up to 'automatically receive an IP (dhcp) and that no info has been pre-added to the configuration. set everything to be automatic and reset your modem and you should be good to go.
Apr 04, 2012 | Acer Aspire 5315 Notebook
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
How to get laptop connected being wireless.
Yes you can connect your laptop to this modem through a wire and still keep the wireless.I am not sure what you are looking to do.All you have to do is connect to the modem wireless after you unplug the Ethernet cable.
Aug 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
NEC Versa FX
The phone jack does not fit because it is an RJ45 network port. If you are using a cable modem or router for your dsl connection you should be able to connect directly with a cat5 network cable.
Or if you have a free USB port you can purchase a wireless adapter like THIS ONE and use it via the USB port.
Nov 15, 2008 | NEC Versa VX Notebook
WIRELESS INTERNET ACCESS
You don't have to purchase anything. Just plug a lan cable from your laptop to the DSL Router.All you need is a lan cable.
takecare.
May 05, 2008 | Toshiba P205-S6267 Notebook
Cannot connect new laptop to internet
Do you have a router set up? If not two things you can do:
1) Buy and setup wireless router wired with desktop and wireless with laptop.
OR
2) Remove network cable from back of Desktop and plug into laptop each time you want to use Internet. Cheaper option but more hassle to switch back and forth.
Mar 21, 2008 | Sony VAIO VGN-N130G/W Notebook
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
