Question about Microsoft Windows XP Professional
Tabs in display properties window
All he tabs at the top of "display properties" window disappeared. How do Ireset them?
  • 33 Answers
You got to perform some updates for that. here the link helps you in steps doin performing that update. click here
DOnt forget to rate this post
Posted on Aug 20, 2008
Cursor disappeared
Here are two things I would try, not knowing your version of Windows:
1. Open Device Manager, double-click each "USB Root Hub, and under the "Power Management" tab, deselect "Allow the computer to turn off this device to save power".
2. In Control Panel, (depending on your version of Windows) either:
A. Open Display Properties, Settings tab, Settings button, Troubleshoot, lower the mouse acceleration to see if that prevents the pointer from disappearing. This is from memory.. I don't have an XP machine running right now.
B. Open the Mouse applet, under "Pointer Options", select "Show the location of the pointer when I press the CTRL key". If there's a way to lower graphics hardware acceleration in Window 7, I can't find it.
Nov 12, 2013 | Computers & Internet
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
Need to change video display in Autocad running in DOS
Hit the "Alt" and "Enter" keys at the same time while in the full screen window. This will change the full screen to a window.
Right click the blue bar at the top of the window. Choose "Properties." Click on the "Options" tab. Make sure the setting is on "Window" rather than "Full Screen."
Click "OK." When you are prompted with save options, choose "Save Properties for Future Windows with Same Title."
Change the properties for the general command prompt. Click the "Start" button. Click "Programs" and "Accessories." Right click the "Command Prompt" icon.
Navigate to "Properties." Choose the "Options" tab. Check the button next to "Window" instead of "Full Screen." Click "Apply," then "OK."
Use the mouse to right click on a DOS program's shortcut. Choose "Properties." Select "Options." Under "Display Options," select "Window." Click "Apply" and "OK."
Open the command prompt or your DOS shortcut. Right click on the blue bar. Click "Properties" and go to the "Layout" tab. Under "Window Size," use the arrows to increase the height and width of the window. Click "OK," click "Modify Shortcut That Started This Window" and click "OK."
Custom Car Parts
Jun 06, 2012 | Autodesk Computers & Internet
I don't see my folders on my external hard disk. When I scan the disk for viruses I can see my folders while they are scanned. When I add new folders to it they don't disappear.
It is due to virus activity. Some virus make the contents of the drive hidden, that is why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset.
Dolwnload iReset and drag and drop the files/ folders on to its window to fix.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it. As long the the virus is there on you PC, you cannot get it fixed. However, if new folders don't disappear, it is likely that you would be able to fix the issue.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | Microsoft Windows XP Professional With...
Hi, My monitor has dull display. After starting my computer, I could see the desktop but after few seconds it disappears. I am sure whats happening. Please suggest me what to do.
My answer will help Windows XP and Windows 7 users.
When the computer starts, start pressing F8 button. After several seconds you will see the following menu.
Safe Mode Safe Mode with Networking Safe Mode with Command Prompt ---------------------------- ---------------------------- ----------------------------
If you have Win XP, there will be a menu item as 'Enable VGA Mode'. In Win 7 you will see 'Enable low-resolution video (640 x 480)'
Select this option and press enter. (XP users will have to enter again).
After the computer is ready, goto display properties and save the resolution.
- In XP right-click on desktop, select 'Properties', Click the 'Settings' tab (last tab on top), and click 'OK' button.
- In Win 7, Right-click on screen and select 'Screen Resolution'. Click 'OK' button.
(Ignore any warnings)
Restart the computer.
Set the screen resolution again to a reasonable setting.
- Be careful! If you set it too high (if the monitor does not support the resolution you select), again the screen might disappear! (Sometimes this happen automatically after installing a game)
Jul 19, 2011 | Dell E176FPC Monitor
Paper curls in brother hl 5250dn
Hello
lick on the "Start" button in Windows and select "Control Panel." Click on "Printers and Faxes" to display the printer icons.
Right-click on the Brother HL's icon and click on "Properties." Click on the tab labeled "Advanced."
Click on the "Device Options" button on the top of the tab, labeled with a wrench icon. In the menu in the "Device Options" window, double-click on "Improve Print Output."
Click on "OK" to close the advanced properties window. Click "OK" once more to close the properties window and save your settings
This should solve the problem
Jun 10, 2011 | Office Equipment & Supplies
Remove genuine microsoft software
the only way is to make your windows genuine or uninstall windows genuine advantage
May 30, 2009 | Microsoft Office 2003 Basic Edition...
Battery icon disappeared from bottom of screen
Right-click on your desktop
Click Properties
Click "Screen Saver" tab
Click "Power" button
another window will appear that says "Power Options Properties"
click "Advanced" tab
check "Always show icon on the task bar" click apply
Apr 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Laptop powers up but does not display desktop
How to enable / disable windows active desktop. Open Display Properties. Click the Web tab in the Display Properties window.
DirectX Help Get the computer into Safe Mode. In Safe mode, click Start / Settings / Control Panel and double-click on the display icon.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Microsoft Windows XP Professional Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
