Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Laptop switches of after 5 minutes when on ac power irrespective of power up mode
Model is
Lenovo 3000N100 0768 running XP. Approx 20 months old. Battery appears completely non functional
  • Ronald Tech
    Ronald Tech May 11, 2010
    What do you mean battery appears non-functional?
    Problem Solver:
  • 16 Answers
You may try to uncheck the box under my computer>right click> properties> advanced> startup and recovery.
uncheck the box for automatic restart.
try to blow a can of compressed air into your fan and heat sink channel.
then try to run windows update or go to to do so..
Posted on Aug 21, 2008
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8
2. From this site, it costs $39.95
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
I have Lenovo Thinkpad R500 laptop, when I poweron the laptop, lights all lights flases on and then off altogether. The laptop is only a month old to the day of purchased.
First, check the AC cord where it plugs into the AC adapter. Sometimes it gets loose there.
If that isn't it, take the battery out of the machine and see if the machine will power on when just connected to AC. If so, try putting the battery back in.
Mar 13, 2011 | Lifetime Lenovo/IBM ThinkPad R500...
My laptop model is lenovo 3000 g430, as my laptop is turned on the screen goes on blinking....pls help me...tell me the solution.
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Lenovo Computers & Internet
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Yesterday My IBM T23 laptop froze..I hit the power button to unfreeze it. It powered down and re started but now it takes about 10 minutes on the Windows XP screen and a good 20 minutes to get to the...
Try to boot up in safe mode this is done by pressing F8 during boot up select safe mode with networking after it has completed and run for a little while reboot up in regular mode.
Hope this helps
Dec 07, 2009 | IBM ThinkPad T23 2647 Notebook
Acer 5002 laptop shutoff randomly
Try to cool the laptop in the sense, do not use it for some time, approx two three hrs then try to re install...
But if your laptop is old then the problem could be because the fans working beneath get old and do not run upto the mark..usually they have two fans i believe...maybe one is conked?
Hope this helps
Apr 04, 2009 | Lenovo 3000 N100 Notebook PC
Lenovo N100 dual centrino
visit u can get certain things to make your laptop faster.......
Aug 18, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
IBM Thinkpad A22e Shutdown early on full battery
First, you should clean the battery terminals. You can scratch the terminals with a metal and then charge. Secondly, you should change your battery, that is, buy a new battery.
Aug 15, 2007 | IBM ThinkPad A22e 2655 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
64 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
