Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
All is dead.
I have a 06 Fatboy with 5800 miles on it. I started the bike up normally. After about 5 seconds the bike just died and will not even do a self test. I do hear a relay click when I turn on the switch. No lights, horn, no nothing. Battery is good. Any help?
  • 216 Answers
I'm always hestitant to offer suggestions on the newer Harleys, my experience is all on 1999 and earlier carb bikes. But try the standard stuff first. No horn or lights leads me to check my connections and fuses starting with the ground for the battery. Torque em up a little and see if it helps
Posted on Aug 20, 2008
'06 Harley Fatboy kills at cruising speed
sounds like maybe your ignition module is getting hot and shutting down, once this starts they gradually become more sensitive to heat and vibration need to replace to see if that is the problem no way to test unless you start it and hold a blow dryer on it if it kills the bike below operating temperatures that's probably your problem. but if you get it to hot with the blow dryer you could fry it all together. risky test I know I personally would try to remount the module someplace where there is more airflow and that will probably fix it too. had to do that with a sportster awhile back. it had an aftermarket crane cams hi 4 ignition behind the covers right next to the rotor cup on the end of the crank no flow what so ever. but that is where crane suggested putting it. I moved it out by the battery and he has never had a problem since.
Jul 11, 2013 | Motorcycles
2003 Fatboy Electrical Issues
Hi Dee, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at BOTH ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Apr 10, 2013 | 2003 Harley Davidson FLSTF Fat boy
06 Fatboy Engine abruptly dies at idle, and hiccups at highway speeds.
This sounds stupid I know... but change out the spark plugs and stay with the standard plug, no platnium or irradium plugs.
Apr 07, 2013 | 2006 Harley Davidson FLSTF Fat Boy
I have a 2005 triumph speed triple, a few weeks ago it was haing trouble starting so I replaced it with ngx iridium spark plugs it started right up after I charged the battery. A week later it was...
Check the inline fuse that is normally close to the battery. Also try again with the battery connected to the charger. Most batteries only have a life of around 5 to 6 years, often less on a bike due to vibration.
Aug 02, 2017 | 2005 Triumph Speed triple
Ridding my 94 FXR Harley and all of a sudden it stopped running, leaving me stranded on the side of the road. Everything was going normal untill it died and when it died it started to sputter as if it were...
The first thing I'd suspect is the battery. I've seen batteries break battery posts, suffer from internal shorts, and all sorts of problems. You FXR, as well as the Softail bikes, is very tough on batteries. This is due to the fact that the battery is in such close proximity of the hot oil tank subjecting the battery to higher temperatures than other model bikes. Vibration is a contributing factor in the Evolution and earlier bikes as well even if they do have rubber mounted engines. I'd take the battery out and take it to an automotive parts store and ask them if they can "load test" it for you. If the battery test good, you need to check to see if the main circuit breaker is tripping indicating a short circuit somewhere.
Good Luck
Steve
Aug 29, 2011 | Harley Davidson FLHT Electra Glide...
How can I no if the miles has been changed on a 2006 Harley Heritage
Ok on an 06 what you do is, start the engine, hold clutch in the whole time, and put the bike down into 1st, then up into Neutral, wait 5 seconds... then put it back in 1st, then quickly go into 2nd, 3rd, 4th. now with the clutch still in and the bike in 4th switch the ignition OFF.
Now here is the test, leave the bike in 4th and start the engine with the clutch held securely in. If it starts up straight away then the miles have not been tampered with. If it needs to be re-cranked then the miles have been adjusted.
Feb 26, 2011 | Harley Davidson FLSTC Heritage Softail...
Charging system problem
start up the bike,put volt meter on battery terminals,if voltage rises with revs ,the anternator is okay,but if no volts then the alternator or the wiring to the battery is suspect
Jul 03, 2010 | 2001 Yamaha V Star 1100 Classic
I have a 97 Fatboy that sometimes loses spark
test or replace your ignition module,and you might find the actual prob by accident the connector for the module sometimes with age lose or only have intermittant contact.a can of electrical contact cleaner should take care of it but those symptoms scream ignition mod dont know why hd dealer couldnt find it but they dont put their best techs on older bikes
Jul 15, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Need help bike died while riding
everything working perfect. Wednesday night i was riding home from work and got about halfway home bike had a small bog while coming up for a turn onto another street pulled in the clutch and stall. Rolled to a stop and fired the magic button. The motor would turn over and act like it wanted to run (had to give a small amount of throttle) for about 2-3 seconds and then would die. Did this about 5 times and the typical dead or low batter clicking occured. Got the bike home and it has been on the tender for the last 2 days and i just put some time in on the bike and sure enough bike will turn over although kida sputtering and making slight backfire sounds (almost as if timing is off) and will run for about 2-3 seconds and dies. I can do this about 4-5 times and the infamous clicking starts to happen again. Now my bike has never been a cold start bike, i always have to give it a bit of throttle when its cold to keep it running, but once it warms up runs like a champ...or atleast it used to. Its a fairly new battery and has been kept on the tender when the bike is not used for a few days. Now the other thing that bothers me is it seems that oil may be seeping out from where the head and the case meet, but very little. The motor does have a slight coating of oil around the gasket area. I did send the motor to ATK back in late 04 or 05 and had the reliability and upgrade done to it but have only about 500 total miles on it since then, with about 400 of those in the last coulple of months. ,Even with a good bike battery 4-5 tries is about all they have.So forget about the battery and go with basics fuel,compression and spark. Also sounds like you need some mapping help, you should never have to touch the throttle when starting. The will run perfect if they are tuned. Do you know what map is in it? Did ATK also change the ECU to a .atj map?,,,
Nov 10, 2008 | 2003 ATK 260
Lands Phones Logo
154 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
