Question about 2wire (1000-400108-001) Router
Crossover Cable What exactly is a crossover cable? Does it connect directly from my 2Wire router to my laptop?
    Novelist:
  • 143 Answers
Crossover cables are designed to connect two DCEs (data communication equipments like modems) or two DTEs(data terminal equipments like computers)
most routers nowadays have smart ports so you can use either a crossover or a straight-through cable to connect a computer. but if your router doesn't have smart ports, it's advisable to use straight-through cables
hope this'll help you
ciao!
Posted on Aug 21, 2008
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
Tip
Using a crossover cable to connect two computers.
Hi.
You can use a crossover cable to share files and folders between the two computers.
A crossover cable looks exactly the same as any Ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
Before proceeding ensure that the cable you are using is a crossover. Crossover wiring isdifferent. By using an ordinary ethernet cable you will not be able to extablish a directconnection between computers.
To use the crossover you will need to disconnect any other cable connection to computer ethernet cards. Naturally both computers must have a wired network adapter installed .
After connecting the crossover, you will need to configure the network connection.
Turn off both computers, connect the crossover (cat5 or cat6) cable, and turn back on computers.
Ensure that all firewallare turned off, and on Vista answer yes to all requests of authorization for the new network.
On both computers go to system properties, and ensure that the two computers have the same workgroup.
Second step is going to Sharing and Security, in system properties, and sharing the files and folder that you want to transfer.
Once the folders are shared you will see in My computer (Computer on Vista) the folder shared from the other computer. Simply copy and paste the files.
You may be asked to restart computer after each step.
If after sharing files and folder you want to share Internet connection, then you will have to assign two IP addresses that are in the same range to the two connected computers.
An IP address is a series of numbers from 1 to 256, in the format XXX.XXX.XXX.XXX . The two IP addresses must share the first three numbers to share the internet connection. In the real case, you can set the IP adresses to 192.168.0.1 and 192.168.0.2.
See also:
on May 26, 2010 | Computers & Internet
Tip
How to connect two computers using a crossover cable.
Hi.
A crossover cable looks exactly the same as any ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
See also:
on May 25, 2010 | Microsoft Windows Vista Ultimate Edition
Networking with xp n windows7 system
If you are connecting directly from computer to computer, you need a crossover cable (Cable specific to direct computer to computer connection) otherwise you need two cables and a hub/switch/router to connect.
Jul 05, 2010 | Dell Inspiron 1525 Notebook
No ethernet connection on my computer thats hooked up directly to the 2wire router. how do i acquire ethernet connection?
My guess is that the 2wire router has a DTE plug and a DCE plug. The DTE plug is meant to plug in to your DSL modem, while the other plugs are meant to plug into computers.
If you move the plug, it might work, assuming you have an upstream and downstream connection on the router.
Failing that:
Make sure the cable is an ethernet cable and not a phone cable,
Make sure the wires are run straight through. If it is a crossover cable, it might be meant to connect a DTE to a DTE without a hub, and it won't connect a computer to a router port.
Try a different cable.
Try a different computer (borrow one, etc.)
Jan 18, 2010 | 2wire 2700HG-B Router (2700HGB)
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
How do i connect my computer to my ps3
to connect your ps3 to your laptop then there a wire that either should have come with the console or one you can buy to connect both devices together
Sep 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
Have no internet on laptop only on pc
Is laptop plugged directly to PC or through a router.If PC to Laptop use crossover cable.Laptop to router Ethernet Cable.
Jul 14, 2008 | Belkin Computers & Internet
Printer will not print
1. Printing from one computer directly to the printer requires a crossover cable. The reason they are telling you to use a router is so you can use a standard wired cable. You can print direct to the printer from the ethernet port via a crossover cable.
2. On the settings. First, go into the nework settings and turn OFF the auto dhcp. What it is most likely doing it switching the IP address on you. Set that to manual or static, then enter the appropriate IP address.
Set that IP address in the driver under the port configuration.
So in order, can the router unless you are going to run your network through it also. And use a crossover cable to run directly from the conputer to the printer. Then turn off the AUTO on the IP address settings and make the IP address static.
Then print out a configuration page to confirm the IP settings then set the printer up from there.
The crossover cable for direct computer to printer is te key.
Any other questions ask away.
Feb 20, 2008 | Xerox Phaser 8560DN Laser Printer
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
94 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
