Question about Lite On NA115 Motherboard
Heatsink I have an NA115 Motherboard as new but no heatsink fan. I have searched all component suppliers web sites but cannot find a cooling unit to fit the cradle. Can you possibly recomend a suitable unit?
Fans keep running high speed on the E210882 motherboard
This may be because the system is running too hot. The fan sits on top of the heatsink which cools the processor. If the heatsink is blocked with dust, the fan will be working harder trying to blow air through the heatsink fins to cool the processor. Open the case and check that the heatsink is clear of dust.
Apr 02, 2012 | Gateway Computers & Internet
Replacemother board dv 8000 hp lap top and trunall ligths trun on but blac k screen.
I'm going to assume it was yourself, or someone besides a tech, who installed this motherboard.
A tech would have the machine working before giving it back.
A) What was the original problem? Why motherboard replacement?
B) Do you know for a fact that the replacement motherboard is a good working unit?
Bought from a reputable dealer, or history of motherboard is known?
C) Did you follow Anti-Static Precautions, and used a ESD wrist strap, and connected it's alligator clip to a good ground source?
D) How acquainted are you with the design of a laptop's cooling system?
Aware of the basic design?
1) Air is drawn in for the cooling system usually from the Bottom of the laptop.
(Air Intake Duct. It is expelled through the Exhaust Port)
2) The air is drawn straight up into the cooling Fan.
Air then is pushed through the fins of the Heatsink
There is a Cooling Tube usually made of Aluminum or Copper. One end is attached to the finned Heatsink.
The other end is usually attached to a small metal plate.
This metal plate sits on top of the Processor.
Heat from the Processor is absorbed by the small plate. The heat is then transferred to the Cooling Tube. (Cooling Tube absorbs heat from the small plate)
The Cooling Tube then transfers the heat to the Heatsink.
The Heatsink absorbs the heat, then radiates it away with the tall, thin fins.
Air going through the fins, and around the fins, helps to carry the heat away.
Also on the same end as the Processor, is usually another small metal plate. This plate sits on top of the GPU.
Graphics Processing Unit, or simply stated as the graphics chipset.
(Essentially the 'Graphics Engine')
The Processor, and the GPU, are the TWO hardware components that PRODUCE the most HEAT.
Example of basic laptop cooling design I referred to above,
Scroll down to Step 29.
Here you see the black Fan Assembly.
To the immediate left of it is the finned Heatsink. Black in color, fins are not visible.
Coming down on the left from the Heatsink is a copper Cooling Tube.
Most of it's length is attached to an aluminum plate.
(Three machine screws hold the plate to the motherboard)
The aluminum plate you see is covering the top of the Processor, and also the GPU sitting next to it.
In looking at the Heatsink/Fan/Cooling Tube combination, for the HP Pavilion dv8000 series of Notebook PC's, I do not see a metal plate for the GPU.
I only see that the Processor is covered by a metal plate.
Heatsink with copper Cooling Tube attached, and small metal plate at the end for the Processor,
4) Motherboard,
This means there is no cooling for the GPU, except for air that may make it's way around, in the inside of the laptop.
A GPU is mounted to the motherboard with a BGA Surface Mount.
Ball Grid Array.
To explain a BGA surface mount;
Your motherboard has an AMD processor socket (Mobile) that an AMD processor fits in.
The socket has the socket holes, and the Processor has the contact pins, which go into the socket holes.
With a BGA surface mount there are no contact pins, or socket holes.
There are Copper Pads, and Solder Balls,
The bottom of the GPU chipset has Solder Balls.
The surface of the motherboard has matching Copper Pads.
The GPU is set into place with the Solder Balls lining up, to the matching Copper Pads on the motherboard.
Heat is then applied at a certain specific temperature, and length of time.
The Solder Balls melt, which solders the GPU to the motherboard.
(Solders the GPU to the Copper Pads on the motherboard)
IF, a GPU constantly overheats, the solder connections start to melt. This creates cold solder joints, and a black display on the laptop's internal monitor.
To summarize;
A) The motherboard that has been installed may have the same problem as the original one, if the problem was poor contact for the GPU.
B) If you did not follow Anti-Static Precautions, there's a good chance the motherboard is now an expensive paperweight, or doorstop.
For additional questions please post in a Comment, or to reply
Oct 23, 2011 | HP Pavilion dv8000 Notebook
Where does one source a replacement cpu heatsink
Any computer store or may have it or kijiji or ebay
You have this vast expanse call the world wide web (WWW)
Happy searching
Jul 31, 2010 | HP Pavilion (F2111-60950) CPU Heatsink &...
Cpu cooler for gateway has just heatsink want to use fan and heatsink not an x mount has rectangle mount
You need to see if the motherboard is compatible with active cooling other wise it will not work.
May 01, 2010 | Gateway Solo (1400HEATSINK) Heatsink With...
Dell Optiplex GX270 sounds like a jet taking off. What is wrong and what do I need to do to fix it?
You have to find out where the noise is coming from. It could be;
1) a fan on your motherboard if it has one
2) the fan on your heatsink that keeps your cpu cool
3) the fan on your power supply unit
4) a cd or dvd rom drive
5) one of your hard drives
6) one or more of your case fans.
7) a fan on your video card if you have one.
You don't want to open your power supply, so if this is the cause of the noise you can replace the whole PSU. Other than that, any other component listed above can be replaced by going to for parts.
Good luck,
Sep 14, 2009 | Dell Heatsink and Fan Optiplex GX270 K4598...
Abit kn9 sli overheating ??
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
Aug 01, 2009 | Abit KN9-SLI Motherboard
Heatsink/fan assembly came loose from my Radeon 9800 PRO card.
Here is a site that shows the replacement of a heatsink fan on Graphics processing Unit...and Another place to find heatsink fans.....I hope this helps...Good luck...and thanks for rating my effort...the Fang. (this is all one link)
This is a nice site to let you cool your card down further than factory specs by replacing heatsink with an upgrade fan.
all one link as well
And this is the actual site that will show you step by to change your heatsink...this is a great site to be a member of ...membership sign up required but free.
Mar 30, 2009 | ATI RADEON 9800 PRO, (256 MB) AGP Graphic...
Heatsink/fan mounting problem
I have never heard of using a certain cpu cooler that would void a warranty.if the cooler is for the cpu then use that 1 i/e the arctic
Oct 04, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
Lite On NA115 Motherboard Logo
53 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
