Question about Regina RG3100 Vacuum
Bags and belts
Can't find the bags ,belts or the hepa filter for my regina vacumm. Model no. rg3100
Hoover H bags work and Royal 4 &5reg. housekeeper belts work.Bought a piece of in. foam and cut it to fit my regina. Haven't found the hepa filter yet. I can't believe they just quit making these items!! Thanks for any help you have given me.
Posted on Aug 20, 2008
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
Russell hobbs vacuum model no 18213 can't get bags?
You can get Menalux 1900 for Russell hobbs vacuum model no 18213 which fit perfectly. Also you ca buy SENCOR SVC 900 bags which fit perfectly and you get 5bags in one package + filter for very good price.
Also there are moe bags that fit to this vacumm model.
Jan 22, 2012 | Vacuums
Removing cover to replace belt
there should be 3 or 4 screws under vacume i beleave philips then it will show you diprame of how to put belt on one end goes on one whell the other whel is attaced to motor put that around that one.
Feb 17, 2011 | Regina RG3100 Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
Replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
I need to replace the belt on my Sharp Vacuum Cleaner: Model ECTU4609. Can't find Owner's Manual and can't figure out how it goes on .
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the belt...you can also clean off the debris while doing this..an added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Proceedure?
You release the water on the reverse stroke, and the machine will pick up in that same stroke. You push the machine forward to position it and pull back slowly as you pull the trigger to release solution and clean the carpet.
Feb 01, 2008 | Regina RG3100 Vacuum
HELP!!!!!
The hose is probably clogged. It is supposed to blow out at the filter. It filters the exhaust air so you don't get dust back into the air.
Oct 16, 2006 | Regina RG3100 Vacuum
Regina RG3100 Vacuum Logo
253 people viewed this question
Top Regina Vacuums Experts
JoeVacs
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
