You may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
my dvd/cd duplicator does not copy, it says error
