In the process of the rebuild you must also replace the primer bulb. There is most likely a pin hole in the primer bulb item 35 this link:
http://www.partstree.com/parts/?lc=tecumseh&mn=TEC-640174&dn=CASERIES_211640174-CA
Also make sure that the orifice in item 36 is clear. You should be able to see a pin hole of light throught this tube.
With the loat bowl removed you should have enough gas flow to fill a spray paint can lid in 10 - 15 seconds. If you do not have this kind of fuel flow... inspect the gas lines and tank. Also make sure there is no debris in the float needle seat. Item 30 of above link.
Thanks for choosing FixYa,
Kelly
