Does not have light on for power. Tried my work computer and a different power cord. It does not appear to be getting power. It looks like there might be a reset button (slot) on the back side. Any ideas, or is is time for a new one. It's probably five plus years old, and uased at home. Thanks, Hank
    Master:
  • 397 Answers
At that age it's most likely a faulty power supply inside the case and the problem is, if it's not a good make power supply it may have taken the motherboard with it, this actually a very common problem and what I spend most of my working hours putting right.
You need to weigh up what is the most financialy viable way out, a new machine or repairs. If you decide to go with a new machine and you have any personal files saved on the harddrive of the old one they can be very easily recovered.
Posted on Aug 19, 2008
SOURCE:
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Dell inspiron 531s will not power on. It worked just fine and after I moved to a different home, it does not power on at all. I have tried different electrical outlets
Assuming you have tested those outlets with another electrical device (such as a lamp) and they are getting power, the problem might be the power cord, or static inside the computer. Try this:
1. Remove the power cord completely from the computer.
2. Press and hold down the power switch for 10-20 seconds. This drains any residual static in the circuitry.
3. Re-attach the power cord. Make sure it is seated firmly on the end that attaches to the back of the computer.
4. Plug it into a known good outlet and try to power on.
If that does not work, try replacing the power cord with a known good one. If it still doesn't power up, the problem could be either the power on button, or the power supply itself. Either could have been damaged during your move. You could open the computer case and see if anything appear loose, or any wires are obviously detached.
Power supply modules do ocassionally go bad on computers. They are not that expensive to buy, and not that hard to replace, though it might be a challenge for a novice. Before you buy and/or replace the power module, be sure to have the machine tested at a local store (Radio Shack, Best Buy, Office Depot, etc) to make sure that is really the problem. Many stores will perform a power supply test for a nominal fee.
Nov 24, 2011 | Dell Inspiron 531s Desktop Computer
The light on the power supply (back of tower) and light on the front button that turns on the computer flashes. This is with the power cord plugged in. The computer does not turn on when I press the...
try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
Oct 06, 2010 | HP Pavilion a622n (PC108A) PC Desktop
Power cord isn't working for Acer 5720
I have had good success with this notebook universal power supply. Just make sure that the clip you need is included with the item. Or you could buy an OEM (original equipment manufacture) model.
Hope this helps.
http://www.cablesunlimited.com/products/Prod_Individual3.aspx?groupcode=I3550
Nov 05, 2009 | Acer (56.04145.901) (5604145901) Power...
Power light blinks
Try using a different AC power adapter. It sounds like the laptop is not getting the proper power or not getting any at all. Have you taken out the battery and tried to power the computer on while plugged in? Also, take a pen or something similar and see if the DC jack (place on the laptop where the power cord plugs in) moves or appears loose.
Mar 18, 2009 | Toshiba Satellite A215-S4747 Notebook
Wd mybook lights flash and cannot acess drive
Allright!!
I dont know if this will work for everyone.
Regarding my previous post i had taken the hard disk out of the enclosure and plugged it directly into the motherboard via sata to no avail.
I then decided to put it back in for enclosure and thought i will try it again.
In device manager i realised the hard disk kept trying to refresh inself and would cut off before it got recognised....playing with the enable/disable option i managed to (somehow) get the drive working(cant explain how yet)
But it worked long enough for me to make my backups.
So i would recomment trying to play around with device manager....might get it to work.
Also its intresting to know that if you try to claim on the warrenty using the serial number on the enclousure you get only one year warrenty but if you open it and enter the serial number printed on the hard disk itself you get a longer warrenty.....
Hope this helps
Good Luck
Dec 11, 2008 | Western Digital My Book Essential Edition...
Mi computer doesn't work anymore. It's an HP tx1220. My warranty has expired and a technician has told me that probably it was the mother board. What can I do?
Ok what do you mean by doesn’t work?
No power? no lights? dead?
Have you tried a different power cord?
I ask this because of these things
  • Laptop power cords can just give out without warning
  • And just because the green light on the power cord is lit does not mean it is putting out enough power or any at all
  • And even if you test the power cord and it reads the correct voltage does not mean it is still putting out enough amperage to handle a load (like powering up the computer) Of course that is extremely rare but I have seen that happen before
  • Before giving up hope I would try borrowing another cord from someone with an HP laptop or one of those I-GO laptop cords with the changeable tips or something or even better yet try your power cord on a different laptop and if the other laptop turns on .then well I am sorry
NOTE: if your power cord has a little green light on it and that light goes dim or starts flashing as soon as you plug it into the laptop then that is a very good indication (9 times out of 10) that your motherboard has gone bad and shorted out somewhere.
But there are too many possibilities of what could be wrong with out more info
When you plug it in do any lights on the computer come on at all?
I wouldn’t give up all hope yet .. that is a pretty nice little computer and worth trying to figure it out.
Nov 25, 2008 | HP Computers & Internet
My ee pc is not turning on
Did you check to make sure a light came on, on the power cord! If not your power cord is shot! Most power cords have lights! Also, take it to get checked out, you might have blown a fuse inside the computer!
Oct 22, 2008 | ASUS Eee 4G Notebook
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Open Questions:
jhgj~$^ Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ CAnaDa how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Amazon Computers & Internet
* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}
Oct 22, 2019 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Ekse
Marvin
Marvin
