Question about Linksys Wireless-G Broadband Router
ACCESSING MY LINKSYS
I have a Linksys Wireless-G 2.4Ghz Broadband Router. The Problem is that I
cant access the internet via the wireless router. I can get a signal between
my laptop and the router i.e the laptop finds the wireless network, but it
will not allow me to gain access to the internet. The router is connected to
my cable modem via an ethernet connection, though if I connect the laptop
directly to the modem I do this via USB. Does anyone know if this is a common
problem or if it may be a problem that I will have to contact my ISP about??
Any tips? I would be very grateful!!!
  • Anonymous Aug 22, 2008
    my computer does not recognize the ethernet cable so Iuse a usb cable with my modem. how do I hook up the router?
    Scholar:
  • 110 Answers
Hi Sorry for the late reply.
Do you have a phone number I could call you on?
Thank you!
-Cameron Bradford
Also, you can visit my website www.pc-fix.us
Posted on Aug 19, 2008
6ya staff
SOURCE:
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
Hallo! my computer do not accept the router. I set up many times but nothing is working with Wlan. in otherside, the internet ist working via broadband - Linksys(INTERNET) - Linksys(port 1) - Computer. It...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 09, 2011 | Linksys Wireless-G WRT54G Router
How do the cables connect? Which cable goes where?
Step 1:
Connect the broadband modem to the router's WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we'll connect the computer to port number 3.
NOTE: It is advisable to connect the computer to one of the Ethernet (1, 2, 3 or 4) ports when setting up the router for the first time. If you have successfully configured the router using a wireless computer, unplug the Ethernet cable which connects the computer to the router for you to have wireless Internet connection. For instructions on how to connect the wireless computer to go online using the Linksys router, click here.
Step 3:
Make sure the power adapter is plugged in to an available power outlet.
3678-005.png Step 4:
Check if the corresponding LEDs on the router are lit. For instructions, click here.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Can't access my linksys on my laptops although I can on my desktop.
Hi ottawakids,
I see that you are having issues accessing your Linksys using your Laptops.
> First Check if the router is detected on the Laptops.
>If the Router is detected and un accessible you ill need to check if there are security settings in the Linksys Router.
>Check if the Linksys has a Network key, or check if the Router MAC address Filtering is turned ON the Router this can also prevent your laptops from accessing the Router.
>If all elsa fails try resetting the Router to defaults and start from scratch maybe some settings are incorrect, setting it to default will fix the issue of the Router not being detected.
I hope this helps.
Have a nice day.
mvincentc
Oct 20, 2010 | Linksys Wireless-G Broadband Router
Cant get on wireless forgot ip for linksys wrt54g
make sure that modem is connected to the linksys, and cords are properly seated.
if cords are seated correctly, hard wire computer to linksys first.
second, access the linksys software thru 192.168.1.1 on the address bar on internet explorer browser.
third,if you will see pop-up box asking for username and password.username must be left blank and password must be set to admin.
forth,inside the linksys software try to access wireless settings.
Dec 04, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G Broadband Router Logo
180 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
