Question about Kenmore 22422 Top Load Washer
Washer stopped working
The washer is only about 3 years old and has been use only on weekends, if that. It ran fine over the weekend but for the last load it filled up and then nothing. The circuit breaker is not tripped and I have turned the timer to make sure it is not "in between." If I put the load size between sizes, it starts to fill. There is just no agitation, drain or anything involving the motor.
Any ideas?
  • gum946 Sep 04, 2008
    I pulled the switch out (destroying it in the process) but confirmed that when I mechanically closed the switch the washer worked.
    I have ordered a new switch and now the challenge will be to install it. What are the problems I am likely to encounter in accessing the connections for the switch and installing the new one in general.
  • gum946 Sep 24, 2008
    The problem was in fact the switch. I replaced the switch, buying it on line, and it cost about $20.
  • 72 Answers
Sounds like an electrical problem, but it can be in any of 3 (or 4, depending on the washer) totally different areas:
1 - The timer could be defective, not sending voltage to the motor.
2 - The motor could be defective.
3 - Something in the wiring (or a fuse or circuit breaker inside the washer) could be defective.
4 - If it's a computer-controlled washer, something in the computer could be defective.
Unless you're familiar (and comfortable) with working with live (110 volt) wiring, have and know how to use a test light or meter and have a schematic diagram of the washer (most of them have schematics on the inside of one of the panels) - and know how to do signal tracing, I'd leave it to a repairman. Electrocution, even if not fatal, can run up some huge medical bills (like from a shattered elbow, when you involuntarily pull back from the wire, and there's a wall stud in the way).
Posted on Aug 19, 2008
Pressure washer brute
I had one to the same thing and the pump went out on the waser and you can buy a new pressure washer cheaper than the pum itself
Sep 21, 2013 | Garden
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
No spin cycle
Make sure spin OFF button is not selected...
Sep 27, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Contol on light blinking, kitchenaide front loading automatic washer, two years old
if this is a flash fault code consult your manual to see what the code is telling you then relist the code for some more advice.
Jan 20, 2008 | KitchenAid KHWS02R Front Load Washer
Obviously there is an issue, perhaps a safety issue.
Suggest don't over-ride anything.
Check your owner's manual to see what blinking light indicates.
Nov 02, 2017 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 22422 Top Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
