Television won't turn on. The standby light is out and the tv is just dead
  • 72 Answers
Check the outlet. If you plug a lamp into the same outlet and it doesn't work, you have no power there (reset the circuit breaker or call an electrician).
If the lamp does work, look for a circuit breaker on the back of the TV - it's usually a red or brown rod (about half as thick as a pencil and less than an inch long) sticking out. Press it in. If that fixes it, fine. If it keeps happening, take it to a repair shop - something is wrong inside an, since it's plugged into the wall (lots of electricity available), it could cause a fire.
If there's power to the outlet and no circuit breaker (or pushing it in doesn't help) you'll need a repair shop. (With the current repair prices and the current prices for TV sets, it may be cheaper to buy a new one. Shop around.)
Posted on Aug 19, 2008
SOURCE:
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Sony TV KDF-E42A10 Projection TV Standby light flashes 4 times. TV turns on for 5 seconds and turns off with standby light flashing 4 times. TV will not stay on.
Your power supply board is not yet dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in solving the problem......
Jan 11, 2011 | Sony KDF-E42A10 42 in. LCD Television
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My television will not turn on. I made attempts to switch outlets and turn on the television manually with no success. I can tell the television is not taking any juice because the standby light is no...
No power to the tv at all?No,LED power light indication or no LED power standy light.The tv power supply board is dead.That the board,where it take in the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 13, 2010 | Element Electronics 26 in. LCD TV
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Akai LCD TV wont turn on
Hello davidshu,
The issue seems to be a power supply problem. The television has a switching power supply. This might be the problem. I would suggest getting it repaired at a television repair shop due to the possible complexity of the work that needs to be done.
Apr 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Ekse
