I have Windows XP and tried to findArcSoft PhotoStudio on my Start menu. It did not appear, so how do I scan something?
  • 72 Answers
Look for scanning software in a folder that sounds like the manufacturer of your scanner. XP doesn't come with PhotoStudio, but installing your scanner probably installed some software that will let you scan with it.
Posted on Aug 19, 2008
SOURCE:
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Dell Computers & Internet
HOW TO SCAN A DOCUMENTS BY USING CANON PIXMA MP145?
Hi
Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
  • Turn on the computer and thescanner.
  • Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
  • Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
  • Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
  • Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
  • Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
  • Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
  • Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
  • Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
Sep 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have installed scanner and disc but cannot find how to use it.I found the test box and that works but now how do I scan?thanks
Canon and other Scanners have both hardware and software buttons to scan documents and photographs.
Scanning with a computer is done with a destination in mind. So the buttons and the software are associated with destinations.
Typical destinations are File, email, Application, and print.
In a simple scan process for copy or print, the item is placed face down on the scanner, then the print button is pressed on the front of the scanner.
The software for the scanner pops up on the screen and the scanner moves the imaging light across the scanner under the glass, reading the item on the scanner. The software sends the image to the default printer and it prints a copy.
You will need to setup your preferences in the software so that a photograph is scanned properly and a newspaper article is scanned to come out clear black and white.
Documents are best saved as PDF files and photographs as TIFF files.
The software will have an expert mode where you can change all the settings and a beginner mode where you let the software decide.
Canon has a great document for your scanner. If it is not on the disk, here is the link. It is called CanoScan 4200F Scanning Guide. I think it will help you to use the scanner for any task.
Apr 24, 2010 | Canon CanoScan 4200F Flatbed Scanner
My scan button does nothing. How can I scan?
When you press the "scan" button on the lexmark, the scanner is trying to connect to a specific software program that in this case you may not have installed.
You will want to try to test the scanner driver directly.
For windows XP and Vista, try the following.
1. Open your start menu
2. Select Control Panel
3. Select "scanners and cameras"
NOTE: for windows Vista, make sure you are in "classic view" to see scanners and cameras.
4. Check whether there is the lexmark listed in this window.
For windows 7, you will need to do something a little different.
2. go to All programs
3. Open "windows Fax and scan"
4. Click on "new scan".
5. Check whether there is the lexmark listed in this window.
If there is no lexmark, you need to check the lexmark website for drivers. If the lexmark is there, try double clicking the icon to run the scan wizard.
Thanks,
Pat
Mar 31, 2010 | Lexmark X2330 Printer
I have windows xp media center. I go to control
I would try booting in to safe mode see what happens
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
If it works in safe mode you may have a permissions issue or infection of some type.
Run a virus scan.
Remove any devices connected to your computer.
Aug 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Start Menu
thank you for the question,will try and help you.
please do a full system scan for viruses etc,pl do update the antivirus before u scan and shut down all un required programmes..
restart after the scan is done then try this first:
you can do system restore back to a point where things were working well,remeber that doing this will make your system back in time hence save all important data,ideally on thumb drive/cd
system restore will be listed as accesories in system tools in XP
if problem still recurs try this:
http://www.mvps.org/ecvogel/kb/XP_speed_up_start_menu.htm
please keep me posted,regards!
Nov 27, 2008 | Microsoft Windows XP Professional
Distorted photos with Canon Scanner & ArcSoft Photo Studio
I'm assuming that this is only occurring in ArcSoft PhotoStudio? You may need to install an application that is more up today and compatible with Vista. I don't know if that version of PhotoStudio is compatible. You should check with ArcSoft. There is a patch for the 2000 version of PhotoStudio...but again, I don't know if PhotoStudio 2000 is Vista Compatible.
http://arcsoft.com/public/software_title.asp?ProductID=141&dyContent=LANG_PATCH
Oct 25, 2008 | Office Equipment & Supplies
Open Questions:
29 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
