Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer freezes but fridge does not get cool
I have a kenmore 22 porcelain plus model# 106.8562782
My freezer is cold and freezin but the fridge is not getting cold.
I have replaced both fans on the refridgerator, the evaporator fan and the fan in the back by the compressure. I believe my defrost timer is bad or my defroster is bad. Where is my defrost timer? What do I need to do to fix this problem?
  • Hector Nieves Sep 01, 2008
    built up ice on the botton vent,inside de refrigerator also on the convertible vegetable/meat drawer temperature control
  • Jeanita Nov 17, 2008
    I have a Whirlpool it freezes, however the regrigerator is not cooling.
    Jeanita
  • 291 Answers
DO u have frost build up in the freezer ? If so you have a defrost problem.. defrost thermostat, timmer or heaters. You can by-pass the thermostat cut it and tape the wire together and put it into defrost with the timmer by clicking it to the right until it clicks the heater you need to ohm out .. the defrost timmer will be good most of the time if it comes out of defrost ... ref. will start running again when u test the defrost thermostat here is a diagram that may help
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00011&componentDescription=AIR%20FLOW%20AND%20CONTROL%20PARTS&documentId=00016472&modelNumber=1068562782&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
Posted on Aug 24, 2008
  • Mike Johnson
    Mike Johnson Aug 24, 2008
    http://www.searspartsdirect.com/partsdir...
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
756 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
