Question about Kitchen Ranges
Kenmore c880 (Admiral) timer has gone blank. Any ideas%
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Sep 09, 2016 | Kenmore Ovens
How to remove oven light cover Kenmore c880 6952190?
I would call the landlord and have him do it .
Feb 16, 2015 | Kenmore Kitchen Ranges
Admiral lnc7766a71 The dryer won't start, and the
Probably the drum belt is broken. Replace it, it's easy.
Oct 30, 2013 | Dryers
Have a Kenmore electric range. A model C880 sold by Sears Canada. One of the "element on" indicator lights stay on even though the elements are not switched on.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 23, 2010 | Kenmore Kitchen Ranges
What is button on the left next to plug outlet on kenmore c880???
As far as i can tell by your model there is no button there is only a meat probe receptacle. if yours doesn't have such a thing it is likely to be an after market part. part number for the meat probe is WB20X5050. hope this helps
Thanks
Oct 11, 2009 | GE Profile JTP56 Electric Double Oven
We have a Kenmore (whirlpool ?) mod#C880 63981961
The temp sensor comes out of the back wall of the oven looks kinda like a chrome rod protruding from the wall towards the top can be on either side but usually left side. if you have an ohm meter you can check it.It should ohm around 1075 at room temp.
Sep 20, 2009 | Kitchen Ranges
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
