Question about StarTech.com (SV231UADVI) 2-port KVM Switch
Cannot connect to the monitor with one computer.
I have a HP WX 8600 that will not connect to a Samsung 305T monitor thru the SV231UADVI KVM switch. It connects directly to the monitor and works fine. My SONY PCV-RZ14G connects to this monitor thru the KVM switch with no problems. I have swapped from one connection to the other, also swapped cables back and forth. no help. All I get when the HP is connected thru the switch is five raster colors.
  • larrycarroll Aug 20, 2008
    I do not have printer problems. I cannot get the 2nt computer to connect to my monitor thru the kvm switch. All cables have been exchanged everything has been rebooted. No problem when the computer is hooked directly to the monitor. This however removes the switch,
    Genius:
  • 1,011 Answers
Dear,
you have to install the monitor to the pc first..
if it is using as default then try to configure your monitor throgh Destop--->right click and then properties--->settings---->advance---->monitor---->properties--->driver---->update driver...
and then let it find the driver and after installations.. check it again by finally reset the monitor or do a restart to the system..
regards,
Posted on Aug 20, 2008
    Master:
  • 638 Answers
Technician help at your place is much advisable.as the settings have to be checked one by one.
Posted on Aug 19, 2008
    Master:
  • 521 Answers
The compression in the PDF output tab that was causing the issue.
We print on a Durst Lambda RGB imaging device to photographic paper. All color management is done as an early bind (raster files are converted to the printer's color space and vector colors are chosen from a palette database). So basically the files must go through InDesign without any color change in raster or vector information. We have clients that require specific RGB builds for logo colors the are present in both their raster and vector files.
Color Management is set to "North American General Purpose 2" with "RGB: Preserve Embedded Profiles" selected.
1) The file is exported as a PDF 1.4, High Quality, PDF/X_None.
2) The PDF was ripped on a Cheetah RIP (Jaws level 3) with no color management on.
3) Solid raster colors such as 0-255-0 will reproduce as 0-255-1.
4) The color differences between the raster and vector are usually 1-4 points.
5) The vector is consistent as was input in the program—it's only the raster that changes. When you are trying to match raster and vectors logo colors it is a killer.
However, I can go into the InDesign (or Illustrator) color settings and turn color management off (This is our current workflow). In doing this the RGB working space uses the monitor profile and "color management policies" are set to OFF. With these settings the RGB raster and vector match. The problem with this work flow is two fold:
1) We have other devices than our RGB Durst Lambda that can use the InDesign color management—Vutek flat bed 3200 and grand format 3360.
2) We have had many occurrences where the custom "color management off" settings have reverted back to the default "North American General Purpose 2"—without any intervention.
  • 157 Answers
Hello
  • John Smith
    John Smith Aug 19, 2008
    HI
    -Try and reset the monitor.
    -Turn the monitor off and on
    -If the monitor has more than one input, try a different input
    - Try and use a different cable when connecting the monitor
    Thanks
    JigSaw
    Fixya Team
    P.S. Dont forget to rate this solution as fixya
Samsung 305t blue pixels
T-con board problem , the Altera chip on the T-con board is having a bad connection to the t-con board or there is some cracked solder , there is only one solution, the Altera chip needs to be reballed beaa576b-373f-400a-be08-cea2c72a8cf5.jpg 25a8ca13-36a4-4a93-bd4e-8a7562a761d6.jpg bc6d274d-e68a-427b-83a3-31f6bc5608a9.jpg SAMSUNG MONITOR 305T REBALLING REPAIR
Aug 19, 2013 | Samsung SyncMaster 305T 30 in. LCD...
I'm running dual Samsung 305T monitors and one of them has been flickering from time to time. It just starts to flash and flicker. Now, it's all green and fuzzy. Still can see everything, but it's got a...
The flickering problem you have is caused by the monitor's t-con board, The Altera chip on the T-con board is having a bad connection because of dead soldering points or cracked soldering joints, the solution for this problem is to have the T-con board Altera chip reballed, its a very advanced repair , only one place will fix it for you and I will add a link for it, you won't easily find a replacement T-con board for this monitor and Samsung is no longer supporting your monitor so that place is your only hope. 7f514c27-5c9c-4e70-b50a-29505054d67b.jpg b5ec5af6-395e-4533-b5ea-9ca10c5ae592.jpg SAMSUNG MONITOR 305T REBALLING REPAIR 728a6cd3-2218-4f75-8f0c-7348e47d15f4.jpg
Aug 02, 2013 | Samsung SyncMaster 305T 30 in. LCD...
Elitebook 8470p not displaying to remote monitor with KVM
Is the laptop actually detecting an output when the KVM is plugged in? Try forcing output with Windows + P (Vista/7) or a function key (not sure what it is for the 8470p).
Apr 09, 2013 | HP EliteBook Computers & Internet
Cannot connect to USB Keyboard or Mouse.
Try disconnecting all the cables and restart the Kvm switch. That fixed it for me.
Jan 25, 2013 | StarTech.com (SV231UADVI) 2-port KVM...
Having issues with my samsung syncmaster 305t displaying red green blue and white. can you help me with this?
since no one answered this, I had the same issue, It was pretty basic but when nothing is connected to the screen (the DVI cable is not connected to any device) it loops in red green blue and white. So just connect something to it and it should work. This monitor is not the most practical since it has no menu and just 1 port.
Aug 05, 2011 | Samsung SyncMaster 305T 30 in. LCD...
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung ML-2510 Printer Sharing With A computer and laptop
dear sir,
there is no need to install any drvier install in to windows xp if yr pronter allreadt install in pc then right click on printer then got to shring then select share as then give a name... after this prossess go to windows vista and open yr pc thru yr network placess it's show printer which connected to windows xp just dabble click then it's show u "Are u sure to install network printer" somthing like that... just click yes or ok... it's help you..:)
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
thanks
plese vote
jo_chinmay
Sep 02, 2008 | Samsung ML-2510 Laser Printer
Samsung syncmaster 305t + 8800GTX ultra msi
Check ALL Connections, reboot, then tell me what you get.
Dec 27, 2007 | Relisys RLT1720 17" LCD Monitor
StarTech.com (SV231UADVI) 2-port KVM Switch Logo
229 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
