Question about Kitchen Ranges
Chef Finesse Duo Oven clock failed-where can I get a repair/replacement?
  • Chef oven Sep 24, 2008
    I have the same problem for last few days and now it is beeping nonstop. What's the solution?
Same problem - Did you get an answer to this incessant beeping noise?
Posted on Jan 19, 2010
Magic Chef over-the-range microwave oven doesn't cook. Clock, inside lights and turntable are fine
If it lights up, the fuse is fine. On all of the recent Magic Chef's I've repaired, the magnetron has been the cause of the problem you described. Another possible common culprit is the high voltage rectifier.
Aug 04, 2017 | Magic Chef Microwave Ovens
How to replace oven door hinges chef finesse approx 15 yo
Can you still find parts for an oven that is that old?
Time to replace it!
Feb 24, 2015 | Kitchen Ranges
I need a manual for an electric Chef Finesse Duo Wall oven. Can anyone help?
do you have a model and serial number? that would help.
Mar 12, 2012 | Ovens
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Re-set Clock due to power black out
Lucky for you(?) I had to reset our clock for daylight savings and checked here before i found my manual. If you're still looking for an answer, press the + & - buttons at the same time, let go and you have 4 seconds to press the + key again to set the time
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
548 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
