Question about Texas Instruments TI-84 Plus Calculator
Minutes When I try to do a conversion from degrees, I get a syntax error when I use the " key above the + button. I use the alpha key, then hit the + for the " function. Am I doing something wrong? Thanks!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Posted on Jan 17, 2010
How to input angle in deg min sec
Use the DMS key, the one with the degree symbol, an apostrophe, and a double apostophe deg ` ``
Enter the number of unit degrees, press the DMS key, enter the number of minutes, followed by the DMS key, then the number of seconds followed by the DMS key. You must press the DMS key after each number, otherwise you get a syntax error. If you have no seconds, enter nothing.
Mar 20, 2012 | Casio fx-300ES Calculator
How do you input an angle in deg min sec on the casio fx-300es
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
-2[3x-5 (2x-3)]=3x-8 how do I do the brackets and the equal sign in this equation? When I try to use the regular = sign in the bottom right I get a syntax error?
Use the other = sign obtained by pressing [ALPHA][CALC]. You also use the[ALPHA] key before entering X,Y,A,B,C.D variables.
The = sign at the bottom that gave you syntax errors is in fact an EXECUTE command. It used to be marked [EXE] on Casio calculators
Mar 04, 2010 | Casio FX-115ES Scientific Calculator
How do I convert from decimal degrees to degrees, minutes, and seconds?
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Degrees seconds and minutes
Sorry, text was posted as clarification request. Here it is
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
How do I set it to factory default settings? When I want to graph or want to do a zoom fit I get a ERR:SYNTAX 1:quit
Seems unlikely that you get a syntax error for both graphing and Zooming. Probably the error is in the function you are trying to graph.
To reset the RAM,
Press [2nd]MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared.
Press [CLEAR] button to erase the above message.
Once Ram is cleared, open the [Y=] function editor and at the Y1= line, enter [X,T, theta, n] key or [ALPHA][X], to draw the simple function Y1=X.
If that works, that means your calculator is OK.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Where is factorial button on ti-83 plus
Not every function on the TI83Plus calculator has a dedicated key, or is accessible through a key sequence. Among the keyless function is the factorial function.
To access the factorial function
  1. Through the catalog of commands: press [2nd][0] (CATALOG) and scroll Up till you reach the exclamation mark !
  2. Press [MATH]. Use right arrow to highlight PRB menu. The factorial function is the 4th in the list.
Syntax
Type the number and use one of the foregoing access methods to echo the exclamation mark on the home screen and press ENTER.
Ex: 12! =479001600
The largest number that you can use with the factorial is 69.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-83 Plus Calculator
No dial tone with 3730
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Jul 02, 2009 | VeriFone Omni 3700
Unable to get any response other than syntax error
Push the button that says "2nd", then push the number "0". This will reset the calculator. After resetting, it should work again.
Jan 09, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Texas Instruments TI-84 Plus Calculator Logo
288 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
