Copiers
Problem for Copiers
Generic problem for all Copiers
Service code 546
By genapitt1 on Aug 19, 2008
can you please help me clear out this code
Comments:
Aug 20, 2008
- the copier is a Lanier 5645 copier/fax/scanner.
Clarification Request
Posted by Bubbabear64 on Aug 19, 2008
What is the make and model of this copier?
Solution #1
posted on Aug 20, 2008
Somewhat Helpful)
Bubbabear64
Rank: Wiz
Rating: 85%, 2121 votes
SC 546 Heating roller
fusing lamp
temperature
fluctuation
The heating roller temperature
changes by ±20°C or more in
one second. This occurs three
times in one minute or two
consecutive times.
• Loose connection of
the thermistor
• Loose connection
between the fusing
unit and main frame
1. Check if the fusing unit is properly set
and connected to the main frame.
2. Check if the heating roller thermistor
connector is firmly connected.
3. Replace the fusing unit
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser... (More)
Answer
i have sharp AR5316. when i turn on the copier indicates H2. then i entered "# interrupt C... (More)
Answer
my mita dc 1260 copier has failed to get into simulation mode
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 780
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
