Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Ascaso Dream Machine heating element
By kalahdotcom on Aug 19, 2008
hello!
At the one year mark from purchase, the Ascasco Dream Machine has stopped heating.
I am happy for guidance on a troubleshoot path that I might travel, and outside that option, is there a repair location in Portland, Or you recommend?
Comments:
Aug 29, 2008
- Thanks so much for the information. I decided to declare the machine dead when Ascaso informed that it was $200 to fix the problem (it would be shipped to them to repair). Too bad I did not keep my proof of purchase and receipt.
Still, this was a lesson learned, which is a good thing in the long run.
Same Problem
Sep 26, 2008
-   My Ascaso Dream died after 11 months so luckily got it repaired under warranty. However, after another 12 months it has gon again. This time the unit has developed an earth leakage (short circuit) that immediately blows any fuse as soon as it is plugged in. -   e8b313
Best Solution
posted on Aug 24, 2008
Helpful)
freetek
Rank: Wiz
Rating: 85%, 1773 votes
A large number of the failures of the broad range of machines seems to be the thermal fuses used to prevent fires if they fail to shut off when too hot.
These are typically in the AC line inside of the unit and welded to terminals (too hot there for solder).
They are kind of bullet-shaped, leads coaxially attached and one end pointed with the lead attached directly to the case, the other in an end that is glass sealed.
These things are designed to melt at a particular temperature and the American made ones were very predictable; the Asian ones are all over the map.
You can determine if the thermal fuse is still intact (has continuity) with any multimeter.
Repair is another matter.
Comments:
Aug 29, 2008
- I think that firm has earned a spot on my blacklist.
(I once kept one that is now banned to a dead hard drive.)
If I was correct about the nature of the failure, a pair of wire clippers, a new fuse (~ $10/dozen), two ceramic wire nuts and maybe 20 minutes would result in a working machine.
All-in-all a repair worth about $25 at the most.
You might want to post your experience with the machine (and the company) on epinions.com to save someone else from the annoyance.
It is also a good place to look for turkeys before you buy another.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
the machine grinds the coffe but it stays in top coffe very light
Answer
Krups 16D1712 water kettle. Won't turn on when button is pressed.
Answer
I get this loud Groan/;Buzz wqhen I press the rinse cycle before grinding the coffee? Any thoughts?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
