Question about Nokia e65 Cellular Phone
Nokia Replacing middle section of cover on E65,How do i access the top screw?
  • 4 Answers
SLIDE THE PHONE UP. AT THE BACK OF THE LCD THERE IS A RECTANGULAR SHAPED STICKER,REMOVE IT AND SLIDE THE PHONE DOWN SLOWLY YOU WILL SEE THE SCREW.OPEN IT THRU THE OPENING THAT YOU SEE AFTER YOU HAVE REMOVED THE RECTANGULAR SHAPED BLACK STICKER.GOOD LUCK
Posted on Sep 05, 2008
SOURCE:
Forgot my password nokia e65, how can i access my phone?
you have put *#7370# on your display screen and insert the nokia's default password as 1234 or0000.
thank you.
Jan 27, 2013 | Nokia e65 Cellular Phone
HOW CAN I UNLOCK MY MOBILE E65
Hi, You can unlock a Nokia E65 safer and easier using unlock code. You can get the unlock code for a Nokia E65 from www.unlocking4u.com/nokia-e65/rs6wp9/ at affordable cost with easy unlocking instructions.
Sep 04, 2012 | Nokia e65 Cellular Phone
Hi i have read your advise on replacing a lcd screen for Nokia 6720 Classic, but i cant seem to find any screws whhen i pull the cover and battery out, Please help
hi, once you have the back cover off and the battery out their should be 6 screws, 3 either side 1 at the top,middle and bottom, they will either be black or silver screws, well their not exactly screws their a small star shaped screw so you need a special torque bit screw driver to undo them or get a really good fitting flat bladed one and try using one of those, but dont mash the head up to much ele you will never get them out.
let me know if you have any problems ok
Mar 16, 2011 | Cell Phones
How to open cover of nokia E65, i want to clean my...
you may see the booklet there is some options are available to open the mobile........
May 21, 2010 | Nokia e65 Cellular Phone
Nokia E65 Navigator
You need an external GPS device with the E65, which it will access via bluetooth. It has the navigator software, but no internal GPS.
You can use google maps and that will use the GMS tower ID's to give you a rough location of where you are.
Feb 16, 2009 | Nokia e65 Cellular Phone
Changing housing on Nokia E65
Hi I have just changed my covers, it is in three parts front, middle and battery cover, first have a good look at your new parts to see where they clip, remove battery and sim, remove the front cover by unclipping it, remove the 4 screws on the back, on the front down the side of the lcd push and slide out the guide rails, watch the small rubber washers at the top and the plastic spacers at the bottom do not get lost, the front can gently be removed watch out for the spring catch that connects the front to the main frame and unclip from the post on the front, open the front just enough to gain access to the one remaining screw holding the middle section, unclip the circuit board at the bottom from the middle frame, prise out the connector bar along the side, watching nothing is catching your frame should come apart, I kept hold of everything in one hand while gently removing the mid section frame that way I did not have to disconnect any of the connectors, clip out the buttons from the side of the old mid section and replace in the new one, then work backwards to reassemble, I had never stripped a phone before but mine is now perfect with its new covers, just take your time and reason it out
cheers
andy
Sep 24, 2008 | Nokia e65 Cellular Phone
Blinking LCD
hi i had the same problem after replacing the lcd.the solution is to flash/update the software of your phone with the nokia software updater.did that to my e65 today and its back to normal.good luck.
Aug 20, 2008 | Nokia e65 Cellular Phone
E65 model nokia software
For best results, post this in the nokia section.
Mar 07, 2008 | SanDisk Sansa c200 MP3 Player
Replace Blub GE Microwave oven Model 1540
On my Spacemaker, access for bulb replacement is on the top of the chassis, which is under the top/side cover. From a diagram I looked at, it appears that yours is similar. If so, you have to:
1. UNPLUG the microwave and then remove the three retaining screws that you'll find on shelf or cabinet above the microwave. Get help; the front of the microwave will be heavy when the screws come loose from the top.
2. Rotate the front of the microwave down a little and lift the rear up about a half-inch. At this point, it is free from the rear mounting plate. Set the microwave on a suitable work surface.
3. Remove the top/side cover piece. To do this, remove all the small screws on the top, the back, and the bottom edges on each side. Then slide cover back about an inch and lift it off.
4. In the middle section of the top of the chassis, you'll then see a cover above the location of the bulb. Lift it up to get access to the bulb.
It's a lame design for an over-the-range unit, but that's the way it is.
Here's a link to a diagram of what it looks like after you get the cover off: http://www.partselect.com/MultiModels.aspx?ModelNum=jvm1640sj&searchTerm=img_00115013i05&RefineSearch=0&imgMfg=GE
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
Nokia e65 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
