Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart Dishwasher What is the best thing that our chef's could use to clean the inside of the dishwasher since there is alot of hard water build up? Thank you. Eric
  • 38 Answers
You will need a delimer. This is typically a liquid chemical purchased from your chemical supplier. Personally, I like Lime-Away from Ecolab
Posted on Aug 20, 2008
My dishwasher is not cleaning well and not rinsing well.It's leaving a film on the dishes'
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaning agent. Try Dishwasher Magic. It is a very good cleaner.
Dec 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaves a film on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning your dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic. This cleanser will dissolve the build up of calcium, thus, preventing the film from forming.
Nov 20, 2009 | Dacor ED24 Built-in Dishwasher
Cloudy will not come off when washed by hand almost looked like it looks scratched and and somewhat of a ring look on top and bottom of glass. I have a water softner too.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Oct 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes are slimy and not getting clean
Concerning the Film.(Disregard if this is not an issue)
Oct 20, 2009 | Whirlpool Dishwashers
My Kenmore dishwasher model 363-1404596 does not clean the dishes completely
Oct 16, 2009 | Kenmore Dishwashers
Not getting much water and not cleaning
Oct 01, 2009 | Magic Chef Dishwashers
Whirlpool dishwasher QUIET PARTNER II doesn't clean dishes, leaves film
Aug 15, 2009 | Dishwashers
Dishes have a powdery residue
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishes have a fine white film when useing hard water using rinse
Check the following to combat this issue.
Not enough water
Clogged spay arms
The most common issue will be a high calcium build up overtime.
Jun 18, 2009 | Frigidaire Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
314 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
