Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf541
Hello our Hotpoint doesn't seem to fill with much water and the clothes smell afterwards could you suggest anything.
Andy
  • 639 Answers
Dear friend,
ngfam at you service!
FOR THE SMELL, RUN ONCE A WEEK WITH OUT CLOTHES ON HOT WITH 1/4 CUP OF BLEACH! MAKE SURE THE NEXT LOAD IS WHITES!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE:
Hotpoint Aquarius wf541 fabric conditioner compartment fills with water and doesn't drain out
There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Apr 25, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius WD440 Washer/Dryer. After a cycle clothes still smell as if there is stagnant water underlying somewhere yet machine has been looked at - nothing wrong. Still working in excellent order...
You can buy a liquid product (I got ours in Lidl) that flushes out and cleans the machine. If one application doesn't work try it again. It's just like cleaning out the dishwasher. Worked for us and it was really smelling!
Aug 24, 2011 | Hotpoint Aquarius WD63 Front Load...
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf541. leak's water when filling. I've cleaned the filter but stil leaking. ?.
Hi
This is either the large pipe that connects from the bottom of the outer drum, to the suds pump inlet, or the pump bodies itself, or the seal inside the pump. This may be tricky to work out where the leak is coming from, but just use a good torch, with the back removed, and watch it through a short cycle. If it is a plastic pump, they usually have small screws holding the 2 parts of the pump body together. Try tightening these, if they are loose. Also if the machine is over 8 years old and has had a lot of use, it will most likely be the pump seal.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint Aquarius WF215 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wf541 model
The sypon tube needs cleaning, you need to poke it clear with something, the tube is part of the dispenser , thouroughly clean every part.
Sep 06, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
WF541 Hotpoint
Have the control board checked first
Apr 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
181 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
