Question about Excel (SS8SATAS5128400R)
Excel question In excel, how do I continue calculating from one sheet to a second sheet? Please help
  • 36 Answers
You can import data from one sheet to another. If you want to bring a total from Sheet 1 to Sheet 2, then in Sheet 2 enter [=sheetname!cell] (without the brackets of course. You will now have the data from Sheet 1 in a cell in Sheet 2 and you can do anything you want with it. One note: if the sheet name has a space in it (Sheet Name) you have to enclose the name in single quotes; that tells it that the whole thing is the name. For example, Monthly Sales, A10 is the total for last month; to put it in this month for a running total, you would enter in Sheet 2 ['Monthly Sales'!A10] (without the brackets again). Now you can have a running total between the two sheets.
Posted on Dec 31, 2008
Please help me to solve the circular reference in 2013 excel file which stop opening the file. Thank you
first start excel and click on formula tab -->Calculation options -->Manual
excel1-yi4l5i2224qkwob0czw2k0fe-5-0.pngNow open file, if asks for update formulae, say no.
Now select entire sheet, select formulas tab--> Error Checking -->Trace Error.
excel2-yi4l5i2224qkwob0czw2k0fe-5-2.png It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Apr 12, 2017 | Microsoft Excel for PC
Export tally data to excel
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
Aug 27, 2009 | Tally T2245 Matrix Printer
Excel work sheets delete,pls how is it restore
Easiest way would be to use the Undo function to work your way back to the point prior to deleting the worksheets. If you can't back up through the list that far, you could close the file WITHOUT SAVING IT, then reopen the original file again. If you have already saved the document after deleting the worksheets, you will have to restore it from a backup (you do perform backups, right?) and continue working fro there.
Apr 15, 2009 | Microsoft Computers & Internet
Open passowrd protected Excel file
Try one of the following:
http://www.google.com/search?hl=en&q=excel+password+recovery&btnG=Google+Search&aq=0&oq=excel+pass
But sometimes it is almost impossible to recover. So be smarter, don't forget your password!
Jan 16, 2009 | Computers & Internet
Query for Excel
i dont think it is possible
Nov 01, 2008 | Microsoft Excel for PC
Attendance sheet in Excel
Hi KDina,
If you need me to work on this project for you please contact me at hdbas8@gmail.com
May 17, 2008 | Excel (SS8SATAS5128400R)
Want to write a code in VBA for a Chart prepared in Excel
Dear Customer,
you have not define your all details,
Plz give all details than & only than some can help you ,
so,Please mention all required details
THNX
May 08, 2008 | Computers & Internet
One problem in the application of excel sheet
I can make out that
You are speaking about creating a macro to take data from one constant updated cell and to put that data into another cell or form sheet.
You will need to get precise help from a programmer on this.
If you want to see a little on macros just open a sheet and checkout the help section on macros.
Some macros can take many hours to write and test.Some make take months.
hope this helps.
Jan 30, 2008 | Microsoft Windows XP Home Edition
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Forgot password
Try this link http://www.download.com/Free-Word-Excel-Password-Wizard/3000-2092_4-10249516.html?tag=lst-0-1 It should help you unlock the Excel file and break the password. Good luck
Sep 02, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
141 people viewed this question
Top Excel Computers & Internet Experts
gary433
john h
Are you an Excel Computer and Internet Expert? Answer questions, earn points and help others
