Question about Gestetner DSc525 All-In-One Laser Printer
Communication failure report
Hi! Everytime something comes over our fax line a communication failure report prints. We can print this document so its not "failing". On the report it stated file no. 3050/Mode forwarding/Destination Folde: Faxes.
Does anyone know how to fix this problem?
  • 48 Answers
Your machine has the capability to forward an incoming fax to a folder on a computer. If the faxes cannot "reach" the folder it will give you the message you described above. if you dont want ur faxes to forward you can shut this forwarding option off. Try going into user tools, interface settings
Posted on Oct 20, 2009
After dialing and scanning to send fax the machine says wait and then goes to print report and starts printing
Dear
Pl. check the tel.line, test for voice communication,if its ok and without any noise, there may be problem with fax communication line(internal), this may be tested by connecting a parallel telephone set and hearing the beep tones while sending the fax.(put the document in the ADF dial any one no. just to cut dial tone press START, ) If no beep tones in regular interval heard. its due to LIU card fault(mostly). You need to replace or repair the card.
Thanks.
Feb 24, 2015 | Canon FAXPHONE B740 Plain Paper Bubblejet
How do I retrieve info from 3210/3220 work centre fax stored in memory
We encourage you to use our knowledgebase MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year! We can solve your problem!
Email patrick@mrc360.com for more info.
Solutions for : How To Print Reports Solution : Print Reports NOTE: Some report options may not be available depending on the product configuration.
  1. Press the [Menu] button on the Control Panel until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [OK] button.
  3. Press the [Left] or [Right] arrow button until "Reports" is displayed.
  4. Press the [OK] button.
  5. Press the [Left] or [Right] arrow button until the required report is displayed. The following options are available:
    • [Configuration] - This report lists the status of the user-selectable options. Print this list to confirm changes after modifying settings.
    • [Address Book] - This report lists all of the fax numbers and e-mail addresses currently stored in the machine's memory.
    • [Send Report] - This report lists the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results for a particular fax job.
    • [Sent Report] - This report lists information about the faxes and e-mails that have recently been sent. The machine can be configured to automatically print this report every 50 communications.
    • [Fax RCV Report] - This report lists information about the faxes that have recently been received.
    • [Schedule Jobs] - This report lists the documents currently stored for delayed faxing, including the starting time and type of each operation.
    • [Junk Fax Report] - This report lists the fax numbers specified as "junk fax" numbers.
    • [Network Info.] - This report lists information about the machine's network connection and configuration.
    • [Network Auth List] - This list shows authorized users who are allowed to use the e-mail function.
  6. Press the [OK] button. "Print?" will be displayed.
  7. Press the [Left] or [Right] arrow button until "Yes" is displayed.
  8. Press the [OK] button to print the selected report.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=301,E=0000000000016129653,K=272,Sxi=4,Case=obj(2601)
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
How do I print a communication report (lists all communication errors receive / send) for the day ?
a config report should do this
hit menu
go to information
select configuration report and print it
there may also be a fax report or jet direct report on its own
Jan 19, 2011 | HP LaserJet M3035 MFP Printer
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Disabling Auto-Print of Communication Result Report
It's in the "user parameters" in the "fax features" menu. No disrespect, but it's a needlessly complicated setting (all of the parameter settings are if you aren't familiar with Ricoh).
You can download the manual here if you don't have one (It's in the Printer /Scanner reference). Look in the index under "Communication result report".......good luck:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp16/mp16en.htm
Mar 11, 2009 | Ricoh Aficio MP1600SPF Copier
My printer will not print
Do you get any kind of error messages i.e. failure to print document or communication error? If you were able to print before, this might have something to do with pending documents on your printer driver. Try to do the following:
click start -> control panel -> printers & faxes (windows xp) / printers (windows vista)
look for your printer icon and check what's the status that would be found underneath the name. It should indicate a number (which is supposed to be 0, meaning no documents on queue) and below that should be ready. You may right click the icon and click "Cancel all documents" if there's an option for that and/or right click again for the "Use printer online" option. Let me know if you're still having troubles.
Jan 01, 2009 | Epson Stylus CX3800 Printer
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
How to print a fax report
Printing a report
Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the Scroll buttons until Report appears and press OK.
3 Press the Scroll buttons until the report or list you want to print
To print all reports and lists, select All Report.
4 Press OK when Yes appears to confirm printing.
The selected information prints out.
Other available reports(CLX-3160FN only)
Your machine prints the following reports automatically or depending on
your setting.
Multi-communication Report: prints automatically after sending
faxes from more than one location.
Power Failure Report: prints out automatically when power is
restored after a power failure if any data loss occurs due to the power
failure.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Gestetner DSc525 All-In-One Laser Printer Logo
95 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
