Question about Shop Vac Vacuums
I have shopvac series 90L-wet/dry vacum. I was using it to vaccu my car. It was the fourth time I had used it for anything. In the process it just shut down. I have not been able to get any results from it since. I purchased it from a Lowe's Home Center on 8/06. What are your suggestions? David
reddevil6
  • 1673 Answers
SOURCE: Shop Vac just stopped
Some do, but it would be in the open by the cord. But you could have a bad cord, switch, or a problem with the motor.
Posted on Mar 13, 2008
SOURCE: how do i go from
can I run my sears shop vac without the paper bag, for dry pickup?
Posted on May 02, 2009
  • 382 Answers
SOURCE: I have a 5.5 hp craftsman 20 litre wet Dry vacum .
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Posted on Dec 18, 2009
  • 10 Answers
SOURCE: My Craftsman wet/dry vac is not picking anything
disconnect hose and check suction at vacuum port. if suction is poor ther turn off, lift lid, e stick coat hanger wire in port from the backside diverter. also, clean filter.
Posted on May 17, 2010
sodeep
  • 3267 Answers
SOURCE: My Hoover Floormate series H3032 won't suction wet
Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material.
Check the machine doesn't just need emptying.
Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut.
Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises.
If there's a filter between the fan and the air outlet (there usually is) make sure it is clean
Assuming the motor is running, check it is turning the fan impeller.
Hopefully, one or other of these will get you somewhere
Posted on Dec 09, 2010
Shopvac wet/dry isnt sucking up water regularly
The filter is for dry pick-up only. Remove it for wet pick-up.
Aug 04, 2013 | Craftsman ShopVac High Efficiency...
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
My vacumn has a aweful smell coming from it when in use. Not motor smell.
smells are usually from bacteria. I have seen this before and you can get O.K results by rinsing the machine with cleaning soloution. I like ****-n-span. try to use a cleaner that you like the smell of as it will leave a little of that smell behind. use the vacum in the wet type aplication and use it to **** up the cleaning solution mixed with warm water with about the same mix as you would use to clean a floor. then after the machine fills up let the cleaning solution set in there for 5 to 15 minutes. dump out the cleaning soloution and repeat the process with clean warm water. If it has gotten really bad then you made need to repeat the entire process one or two more times. I also take the pick up hose and clean it with some cleaning solution then rinse outside with a water hose.
Apr 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Do you need a special filter for wet application
Yes. The following site shows the filters and which is used for what. Due to potential motor damage, I wouldn't use it without the proper filter.
http://www.shopvac.com/shopvac-accessories/Departments/Wet-Pickup.aspx
Jan 03, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
Dec 18, 2009 | Vacuums
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Vacuums Logo
206 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
