Question about Garmin iQue 3600 GPS Receiver
Need to replace memor4y battery in garmin hanhheld gps.Please advise how to. regards George the internal battery is dead on my old garmin gps III , can it be replaced ?
  • smiley27028 May 11, 2010
    my listing is for a garmin gps III
  • Anonymous Mar 25, 2014
    How do I replace internal battery on a garmin gps 12cx
I have the same problem. how can I get it fixed?
Posted on Oct 11, 2008
    Problem Solver:
  • 12 Answers
Battery can be replace for around $14 (look at eBay and search for "battery ique 3600"
See this video for insrtuctions:
http://www.viewdo.com/now_viewing.php?id=205
Posted on Oct 08, 2008
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
Runs fine on external power. Does not work on batteries.
Hello :
It seems that the batteries are dead . You need to replace them . When battery is dead it can't be recharged anymore .
If that didn't fix the problem , then I recommend you to clean the batteries base where the batteries set with a q-tip and alcohol containing liquid .
PLEASE RATE !
REGARDS .
Apr 15, 2010 | Garmin eTrex Vista Cx GPS Receiver
GPS III Pilot? will not power up
Try the dc plug too (also make sure the battery connections are good in the caste). IF still no power up, the internal battery may be shorted. Lots of info online for replacing the internal battery. Good Luck!
Sep 13, 2009 | Garmin GPS III
Have a garmin gps3 that will not power up - batteries checked OK. gps hasn't been used for a couple of years. replaced batteries with new - no go
IF it stil won't pwer up with the dc plug, I suspect the internal battery. Lots of info online on replacement, you can CAREFULLY snip one lead as a a diagnostic test to take it out of the circuit. Good Luck!
Sep 07, 2009 | Garmin GPS III
Dont want to turn on
IF the internal battery is dead, which happens, it will no turn on even with good batteries or the DC plug. Lots of info online on how to replace it, make sure you use the correct type.
Apr 05, 2009 | Garmin GPS III Plus GPS Receiver
Garmin V
I think I may have found the solution.
A reply for a post on another site:
I visited the Garmin Corp office to seek help with that problem. If the shut down occurs right after satellite acquisition and the screen may show just a narrow black line going across it, it is likely due to some program changes the sattelite folks did without telling the software programmers. Garmin web site has a free download fix for the problem. Another option is to go into your settings and turn off the WAAS. Hope this helps. Go to the web site, check downloads, find your model gps and there you go. Good luck.
I disabled WAAS and so far so good.
I couldn't find the fix on the Garmin site.
HTH.
Oct 12, 2008 | Garmin GPS III
Replace internal battery on garmin gps3
Hi - I have a Garmin GPS 2 plus unit which is around 10 years old. I haven't used it for about 2 years. Initally it powered up and eventually found satellites. I switched it on the following day and it will not power up. I have changed batteries but nothing works - tried a master reset but agin nothing - it appears to be dead ?
Ali
Aug 29, 2008 | Garmin GPS
Garmin gps III / internal battery replacement
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Jul 07, 2008 | Garmin GPS
Garmin GPS III LCD screen problem
I have a GPSII+ that has a screen problem. Several of the x and y coordinates have failed and I think it is due to condensation in the unit due to hot day temps then cold nights. If I open it and dry out the unit for a while... the display will be better but will not return to full display. Some of the X and Y lines don't work.
May 12, 2008 | Garmin GPS III
Garmin iQue 3600 GPS Receiver Logo
187 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
