Question about Mitsubishi VS-50501 50" Rear Projection Television
Mitsubishi projection Model # VS-50501A (Power cutout)
Hello, is the power up problem for VZ chasis similar in VS? I have a Mitsubishi projection Model # VS-50501A that cuts out after 2-3 seconds. It is 11 years old and I wonder if it is a project worth getting into. I have the TV apart on saw horses. Any thoughts?
Thank you, Kevin qfd333@comcast.net
  • qfd333 Aug 19, 2008
    Hello, I tried that and I did not receive any lights (codes).
  • Mitsubishi Master
  • 8,617 Answers
They are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Posted on Aug 19, 2008
  • Sonny Berry
    Sonny Berry Aug 20, 2008
    okay that means it wasnt shutting down for protective reasons. Check the votage regulators and horizontal out put transistors first.
  • 4 Answers
VZ4 Power Shutdown at Power on
1.) L902 (351P1550101) Inductor coil mounted to right front middle of power board (this was my problem fix component, all the others listed tested fine but are possibilities.
2.) D913 (Minifuse)(264P722010),
3.) Z901 (283P0390202), SF64 Diode next to C925 in secondary
4.) D5A09 (264P244030) Zener diode next to IC5A01
Posted on Nov 06, 2011
  • Richard Partin Nov 06, 2011
    Also helps to notice if the set will come on in a room below 72 degrees.
I have a Mitsubishi VS-50501A Rear projection TV. When I push the power button the green comes on for a few seconds then goes out. The TV will not power on.
This one may or may not have the self check:
when green light goes out on front of set press menu and input (device) buttons at same time and hold for at least 5 seconds and let go: if it has self check power light should blink a two digit error code and repeat it several times.
If no response it indicates some problem in main power supply (set is in shut down)
I need to know what skills you have; what I have seen mostly in these early sets is bad solder connections that develop on main boards; I can tell you where and what to look for but it involves getting at the boards and being able to solder.
Before you rate this information let me know what you find and remember I am here to help you.
SD TECH
Aug 15, 2011 | Mitsubishi Televison & Video
HOW DO I ADJUST THE COLOR ON MY MITSUBISHI VS-50501A WITHOUT THE ORIGINAL REMOTE
You can order the remote for your model through www.tvrepairworld.com they can get any remote for any television. and the remotes dont require any programing since theyre designed to operate a specific model number TV.
Jan 06, 2010 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Sep 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Power interrup
Good Day, qfd333;
To find suspected liquid the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Good Luck, big IRISH.
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs-50501a rear projection tv
This is a high voltage problem that is going to be very costly.Sorry!
May 20, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50501A convergence problem
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi big screen tv
The VS5043 shuts down for many reasons. The most common are power supply issues. Bad caps, open resistors, shorted regulators, and missing voltages will cause the set to shutdown.
In my notesI have a location of components known to cause your problem( R5A03,L5A00,D5A21,Q5A04,Q5A03,C5A19,L902,IC900.IC700) All the parts listed are available. As I stated above there are many reasons for shutdown such as a bad flyback transformer that may not be available anymore. However, this type of failure needs to be properly diagnosed by a qualified technician. Good luck!
Sep 23, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
495 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
