Question about Protron PLTV-32 Television
No power I had a power outage. Everything came back on but my tv. I have a surge protector and this still happened. Is it a fuse??
  • 1 more comment
  • dculican Aug 19, 2008
    There is no light, no anything...which leads me to the fuse...
    Do you know if it is a common fuse and if so, do you think radio shack will have it?
  • dculican Aug 20, 2008
    I pulled out the switch assembly (with about 4 wires coming out of it and 1 ground wire) I took it to Radio Shack and the 20 something kids working there looked at it funny. I will take it today to a real electronic place and hopefully they can help me out. I have the power cord also, Is there a way to test the switch without being hooked into the TV?
Jaime, there are multiple fuses??
Posted on Aug 20, 2008
  • 2,322 Answers
If you see a light on the front panel, is not the fuse but something else in the power supply circuit board or could also have damaged the main board due to the poor voltage regulation of these power supplies.
Posted on Aug 19, 2008
  • 2 more comments
  • Jaime Hernandez Aug 19, 2008
    That is correct. check the fuse first and if that is open make sure you put one with the same current ratings.
    The fuse should be a standard 250V/5 Amps fuse and radio shack should have it. Once you open the bcak vover of your TV, you will see it there.
  • Jaime Hernandez Aug 20, 2008
    Click here and here to see pictures of two different fuses.
    @ danculican,
    It depends on the revision of the board but normally they use inductors as protection instead of a fuse in the secondary side of the power circuitry. There should be one fuse in there. Compare the pictures from the link and see if you can find it.
AFTER FEW POWER OUTAGES, FREEZER TEMPERATURE KEEPS BOUNSING BETWEEN 5 AND 20 DEGREES, REFRIGIRATOR SEEMS TO WORKING FINE AND KEEPS TEMPERATURE.
Check the cabinet temperature with an independent thermometer. If it is does keep a stable temperature the problem would probably be electronic.
A power outage is often accompanied by a voltage surge. Sensitive electronics and computers can be damaged by a voltage surge. People are used to protecting personal computers with surge protectors but fail to realise these days almost everything is a computer or contains a computer. Radios and tv sets are computers and so are cars and even the humble toaster these days has some computing power.
Today almost everything but the cheapest of appliances should be protected. A minimum surge protection can be obtained by using an area surge protector.
Aug 18, 2016 | Liebherr Refrigerators
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
I have a Panasonic plasma, & we just had a power outage today... every time we have one, it won't power back on. The call center is closed for the night, & I can't remember what they told me to do the last...
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
How can I stop the tv from coming on automatically after a power outage...the tv was off when it happened
Try unplugging it to reset. the microprocessor. (unplug, wait 30seconds to 1 minute then plug back in)
I highly recommend a good surge protector for your TV, as these power outages can severely damage & or shorten the life of your unit
Jul 22, 2014 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Had a power outage and now my tv is totally dead. Any suggestions?
It died from the power surge. If it is still under warranty, check if it covers power surges. If not, you should probably buy a new TV. Buy a good quality surge protector just in case something like this happens again. It's a good idea to get surge protectors for your other expensive electronics too.
Mar 06, 2011 | Panasonic Televison & Video
No power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
Jan 27, 2008 | Hitachi 60VX500 60" Rear Projection HDTV
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Protron PLTV-32 Television Logo
52 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
