Question about Brother GX-6750 Typewriter
Key strokes The keys pressed are not the ones printing. Typing different letters and symbols instead of whats on the keys. What can I do to correct this?
    Scholar:
  • 132 Answers
Hi
I suspect that the key with and asterix (with a circle) around it is stuck (or the electrical mechanism is stuck) - or similar key with similar function.
the characters appearing - do these relate to 'the key in question, but as a special character ??
I have the manual for the typewriter, but there is nothing immendiate to explain your problem.
Feel free to respond to this with an email address, and I will gladly forward it to you.
Regards TC
Posted on Aug 19, 2008
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
Some of my keys are printing differently in my Toshiba Satellite A75 S209 Laptop
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Feb 20, 2012 | Toshiba Satellite A75-S209 Notebook
When i am typing @ cant instead @ the letter is " please help
The keyboard is set up wrongly or the laptop isn't one set up for your country.
If you get " when typing @ try typing SHIFT and 2 for the @ symbol.
You can change keyboard settings in Control Panel.
Feb 13, 2011 | Toshiba Satellite A60 Notebook
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
Typewriter printing different key than one hit
Check and see if the pitch selection is in PS.
DickyO
Mar 29, 2009 | Office Equipment & Supplies
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Brother GX-6750 Typewriter Logo
143 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
