SOURCE: how do you replace the pre filter catch on a dc07
The pre filter retaining clip is easy to fit, but hard to get the old one out. This is the easy way to do it:-
Turn the machine over, where the bottom of the clip should be is a plate blocking access, it is held in place by a torex headed screw. DO NOT remove this. Instead drill about an 8mm hole through the plastic plate, roughly in the middle level with the large 'A'. This will give you access to the bottom of the clip. Put a flat blade scewdriver through your new access hole and push out the broken clip. It should spring out with a couple of knocks with the palm of your hand. Turn the machine upright and push in the new clip. The hole is not seen and as long as it is a neat job, does not affect the strength of the plate.
Cheers Malc.
or take the torx screws out and remove the vent that they hold (this is hard) you need to work it like crazy (taking the hepa filter out (under the dustbin) helps). then you can just use a hammer and flat head screwdriver. no drilling needed
